mtv wrote:C185D wrote:akgreg wrote:so I went and talked to the Airframes AK guys about my desire to put the Desser tire on their 10x6.50 wheel and the response I got was less than what I would call professional. Zero desire to try and see what could be done to come up with a solution. Just bad mouthing another company. I sure do hope that Grove comes out with their 10x6.5 tubeless wheel sooner than later. I think they will be a great combination for those wanting something in between Air Hawks and Bushwheels.
I looked at doing the same thing and just drilling the valve stem hole myself. I'm glad to see that ABW has some competition, they make great quality products but 1800$s for a 31" tire is insane. And yes for all the keyboard heroes out there I KNOW it's not cheap to get PMA approval or an STC but they would sell a lot more tires if they were just a bit cheaper. The Grove wheel sounds nice but I would never run a tubeless tire, it's just asking for trouble, the safest bet is putting screws in the beads.
Actually, since you're close, you should go to ABW and get an idea of all the hand work that goes into those tires. And, yes, the BIG difference is that Bushwheels are STCd. And that is huge. Just because the Dessers are TSOd does not mean you can just bolt them on, unless of course, you're Experimental.
Yes MTV I know if you drill a hole in the wheel its experimental use only and yes I know that the tires aren't STCd thanks for reminding me. And yes I know how the tires are made but their TOO expensive along with all the other parts they have. I along with everybody else still buy their products but that's only because they are the only guys that sell them and they know it.
