Backcountry Pilot • DHC-2 Beaver Manuals
6 postsPage 1 of 1
Does anybody have copies of maintenance/repair/IPC manuals for the beaver that they'd be willing to share? Having trouble tracking these down.
sdaudie offline
Aircraft: DHC-2
Re: DHC-2 Beaver Manuals
The Operator's manual alone is about two to three inches thick. Same for the maintenance manual. "Sharing" might be a bit of an operation in other words.....
And, BTW, didn't you receive a copy of the Operators Manual with the plane? If not, are you legal to fly without it? Here's the requirement from the TCDS:
NOTE 1. The following must be in the aircraft at all times:
Approved deHavilland Beaver DHC-2 Flight Manual, Current Weight and Balance Report, including List of equipment in certificated empty weight, and Loading Instructions.
If you don't have that manual, I'd get in touch with Viking Air Limited and order one, ASAP.
I’m not looking for the operations manual. Just maintenance manuals. Hoping somebody had a pdf of them, but not holding my breath.
sdaudie offline
Aircraft: DHC-2
Kenmore Air parts department has them on the shelf, bring $$$. https://www.kenmoreairharbor.com/parts.html
You can try Viking directly, bring Canadian $$$. https://www.vikingair.com/customer-support/spares-support
Halestorm offline
Aircraft: C-182E Pponk
These pop up on Ebay every now and then if you save a search for DHC-2
nickelb offline
Aircraft: 180H, DHC2, LA4
I have PDFs of all of these if you PM Me
nickelb offline
6 postsPage 1 of 1
