Mapleflt wrote:I’ve come to the conclusion that apparently shoes do matter. Please tell me we are not going to address other forms of clothing. I don’t wish to know how or when others wear their thong.
StuBob wrote:Mapleflt wrote:I’ve come to the conclusion that apparently shoes do matter. Please tell me we are not going to address other forms of clothing. I don’t wish to know how or when others wear their thong.
When I was a kid, “thongs” were footwear. The underwear may be named for its resemblance, having a Y shape, the center of which divides something anatomical.
Once the underwear.. .uh. . . appeared, and after a brief period of using the same word for both items, the footwear had to find a new name. After a short time in which they were called an ethnically insensitive name rhyming with “flap,” as in “*ap flaps,” they became “flip flops.” This transition was probably aided by one-time Albatross pilot Jimmy Buffet, who made mention of failed footwear in “Changes in Latitude, Changes in Attitude.”
And now you know. . . . . .The Rest of the Story!
DENNY wrote:Several factors are involved with proper foot gear. First off is the aircraft equipped with heel or toe brakes? How much ankle flexion is required to apply full rudder or brake with out applying the other. What is the seat hight? What is the pilots leg length and ankle flexibility. This is a backcountry site so being able to instantly tap a brake without shifting the foot to the brake pedal is important for control on a lot of strips/conditions. For myself anything seems to work fine in the cub. I land duck foot with my heel on the brake and toe on the rudder Hiking boots/bunny boots have enough flexibility to apply full rudder without applying the brake. The heel always stays on the brake and I can apply them quickly. I feel this is an important thing that instructors fail to point out to students that learn in toe brakes. They land with foot straight up and have to move the heel back and inboard to apply the brake. The Cessna is a different story and much harder for me. I am not that tall and have short legs so my seat is very forward and raised to see over the dash. I have to concentrate on keeping my ankle flexed fully back when landing so I don’t hit the toe brakes this is harder in large/high boots. Once again I keep my feet just off the floor heels on rudder with toes on the pedal for a quick tap if needed (it has saved me more than once) I prefer to use a low quarter walking shoe with the Cessna and carry bunny boots if needed. High top hiking boots also work well If I leave the tops laced loose. I am also working on having the seat lower to have a better leg angle. Every plane is different so just as you would check full movement of the stick/yoke make sure you have full and INDEPENDENT rudder/ brake control. If you can’t wear the boot/shoe required to walk out due to control issues then at least keep them in the plane. So the answer is yes shoes matter but it depend on several factors.
Denny
DENNY wrote:.... The Cessna is a different story and much harder for me. I am not that tall and have short legs so my seat is very forward and raised to see over the dash. I have to concentrate on keeping my ankle flexed fully back when landing so I don’t hit the toe brakes this is harder in large/high boots......
hotrod180 wrote:DENNY wrote:.... The Cessna is a different story and much harder for me. I am not that tall and have short legs so my seat is very forward and raised to see over the dash. I have to concentrate on keeping my ankle flexed fully back when landing so I don’t hit the toe brakes this is harder in large/high boots......
I had this same sort of issue with my 180.
Strange that I didn't have that issue in my old 170, which had the same rudder pedals,
but the 180 pedals angle might be a bit different.
Anyway, this cheap & easy mod fixed the problem.
mtv wrote:DENNY wrote:Several factors are involved with proper foot gear. First off is the aircraft equipped with heel or toe brakes? How much ankle flexion is required to apply full rudder or brake with out applying the other. What is the seat hight? What is the pilots leg length and ankle flexibility. This is a backcountry site so being able to instantly tap a brake without shifting the foot to the brake pedal is important for control on a lot of strips/conditions. For myself anything seems to work fine in the cub. I land duck foot with my heel on the brake and toe on the rudder Hiking boots/bunny boots have enough flexibility to apply full rudder without applying the brake. The heel always stays on the brake and I can apply them quickly. I feel this is an important thing that instructors fail to point out to students that learn in toe brakes. They land with foot straight up and have to move the heel back and inboard to apply the brake. The Cessna is a different story and much harder for me. I am not that tall and have short legs so my seat is very forward and raised to see over the dash. I have to concentrate on keeping my ankle flexed fully back when landing so I don’t hit the toe brakes this is harder in large/high boots. Once again I keep my feet just off the floor heels on rudder with toes on the pedal for a quick tap if needed (it has saved me more than once) I prefer to use a low quarter walking shoe with the Cessna and carry bunny boots if needed. High top hiking boots also work well If I leave the tops laced loose. I am also working on having the seat lower to have a better leg angle. Every plane is different so just as you would check full movement of the stick/yoke make sure you have full and INDEPENDENT rudder/ brake control. If you can’t wear the boot/shoe required to walk out due to control issues then at least keep them in the plane. So the answer is yes shoes matter but it depend on several factors.
Denny
Denny,
I teach pilots in Cessnas to keep their feet slid waaaay down on the pedals, so that the toes of boots are on the bottom of the pedals, and no more. If you need brake, it’s easy to slide a foot up and press. If you need brake any quicker than you can accomplish that, you aren’t paying attention. That was Tom Wardleigh’s program and it works.
DENNY wrote:mtv wrote:DENNY wrote:Several factors are involved with proper foot gear. First off is the aircraft equipped with heel or toe brakes? How much ankle flexion is required to apply full rudder or brake with out applying the other. What is the seat hight? What is the pilots leg length and ankle flexibility. This is a backcountry site so being able to instantly tap a brake without shifting the foot to the brake pedal is important for control on a lot of strips/conditions. For myself anything seems to work fine in the cub. I land duck foot with my heel on the brake and toe on the rudder Hiking boots/bunny boots have enough flexibility to apply full rudder without applying the brake. The heel always stays on the brake and I can apply them quickly. I feel this is an important thing that instructors fail to point out to students that learn in toe brakes. They land with foot straight up and have to move the heel back and inboard to apply the brake. The Cessna is a different story and much harder for me. I am not that tall and have short legs so my seat is very forward and raised to see over the dash. I have to concentrate on keeping my ankle flexed fully back when landing so I don’t hit the toe brakes this is harder in large/high boots. Once again I keep my feet just off the floor heels on rudder with toes on the pedal for a quick tap if needed (it has saved me more than once) I prefer to use a low quarter walking shoe with the Cessna and carry bunny boots if needed. High top hiking boots also work well If I leave the tops laced loose. I am also working on having the seat lower to have a better leg angle. Every plane is different so just as you would check full movement of the stick/yoke make sure you have full and INDEPENDENT rudder/ brake control. If you can’t wear the boot/shoe required to walk out due to control issues then at least keep them in the plane. So the answer is yes shoes matter but it depend on several factors.
Denny
Denny,
I tried that as did one of the other owners, trying to get the boot to slide up when you have the rudder to the stop just does not work smooth enough for us in windy conditions. My 180 time is low so I am sure I am behind the plane in general. Putting the blocks on the lower pedal would solve the issue if you can get the IA to approve.
Denny
mtv wrote:.....The pedals in my old 170B were worn out, where they pivot. We contacted Cessna parts, while I held my breath. Turns out the only pedals they still stocked were the very late model pedals, which are made from some sort of high density plastic, with bushings. Coincidentally, the pedal shape is very similar to what you show here.
I REALLY liked those pedals. The good news was, at that time, a full set of four cost me $85. I figured there was some sort of mistake in pricing, but didn't bring it up. I've thought about buying a set for my current ride. MTV
WWhunter wrote:Since we are getting close to a$$ deep in snow around here, I flew the other day in Air Force extreme cold type mukluks for the first time. Probably best type of winter boot I have ever used while flying. Very flexible and more like having a huge tennis type show on verses a solid soul type.
