Incorrectly doesn't equate upside down! LOL. These bad boys are installed right side up but in the wrong spot.Bigrenna wrote:We cant see from the pic in this thread... Ryan had told me on the telephone they were upside down.
I just don't think that they wanted to spend extra time to do it right the first time. Just like drilling out the seat rail holes instead of installing the new McFarlane rails that they had on hand. It'll get fixed right but it is going to take forever.Rob wrote:I am of the opinion that while the more technical thoughts and concerns shared here are true and accurate, that doesn't make them right for in this application.
That installation shows either;
A) a shortage of pride in work performed , or
B) a shortage of skill in the work performed
I believe the installer of that step honestly thought you'd never see the back side.
I agree with bigrenna, poor prep, poor doubler construction, and questionable (possibly illegal) methods...
Sure it's just a step install, but I suspect you paid fair market value for this work. You did not receive a fair product in return.
Take care, Rob
X2. If they cut this corner, I'd be worried about what other corners they cut...Skalywag wrote:Your not alone in the shits, its been a tough road for many of us. Thats why so many folks here warned against doing much more than getting airworthy at the get go...Airframe and power plant are vitally important, everything else is minor perks and big $$$
Still, so frustrating to see a corner like this cut. If this install reflects the integrity of the mechs that did your refurb (?), you really need someone high caliber to go back through everything they touched! At least, thats what I would do...be careful who you trust from here on out; my advice is listen to the folks that have thousands of hours owning these planes, crazy concept right [emoji23][emoji379]
180Marty wrote: When I look at this picture of Rob's 180, it looks like the step is ahead of the door post so am curious what is on the back side for this install.
asa wrote: How did you balance the step on its edge like that? Can I get a tutorial?
180Marty wrote:No steps on mine. Hotrod, when I look at your step, it looks like the rear two bolts (one above the other) replaced rivets on the front row of the door post----those number 5 flush ones that like to smoke on early 180's.
lesuther wrote:Adhesives, like beer, are the solution to, and cause of, many of life's problems.
Effective adhesive joint design is very different than mechanical fastener joint design. For one, adhesive bonds are strongest at a particular thickness for a few technical reasons that would bore most, and they are very weak in tensile stress for the same technical reasons. Every means of eliminating tensile loads must usually be taken to make adhesives a practical solution. Conventional mechanical fasteners are used where there are couples in a part for this reason- the pre-loads from rivets and screws and the higher tensile modulus for the fasteners mean the stress is accommodated by the fasteners rather than the adhesive by orders of magnitude in practical cases. And mechanical fasteners in the most effective joints are most often never intended to even experience shear (even wing skin rivets). The pre-load from solid rivet installation or bolts is intended to keep the friction of the joint high enough to resist relative motion and thereby eliminate shear, and the pre-load itself eliminated reverse loads on the fatigue life calculations by orders of magnitude.
The use of adhesives is highly advantageous when the joint is appropriately designed for both weight and strength reasons. Inappropriately designed joints are a tragedy waiting to happen. By the idea that the adhesive itself is stronger than the substrate is false in the case of metal/adhesive joints. The joint itself needs to be designed so that the shear loads imposed by the adhesive meet or exceed the principal (Mohr) stresses of the joint members.
Here is a bonded space truss instrument I designed and built in my shop for an NASA atmospheric science experiment that is flying for a couple of weeks above the arctic circle in June and Antarctica for up to a few months later this year. The joints are all pinned, and the bonded joints are entirely in shear. Other fastener methods were employed where moments were possible during parachute opening loads and ground impact. The use of adhesives where appropriate saves over 100 pounds of payload mass, allowing longer and higher flights (up to 140k').
pilotryan wrote: This is why I like to post here. When I go through this area I will make sure that the skin and the doubler get cleaned up and installed properly. What adhesive would you consider using on this?
Rob wrote:pilotryan wrote: This is why I like to post here. When I go through this area I will make sure that the skin and the doubler get cleaned up and installed properly. What adhesive would you consider using on this?
This suggests that you intend to remove and potentially reinstall this step. You didn't ask for suggestions, but I would like to offer a thought for you to ponder.
Do you intend to install larger tires on this plane at any point? The reason I ask, is that I am 5'6", and have yet to see a need for a step when fueling my 180. Standing on a 29" tires allows me to reach the fuel as easy or easier than a step would.
Like everyone else, as soon as I got my 180 home I started buying up every mod on the planet for the old girl. Finding a guy in Canaduh who makes copies of the boot cowl step, strut step, and boot cowl handle, I immediately ordered the package. In fact I ordered a ton of stuff (almost literally)... and then it hit me... The 180/5 series planes started life as 1500lb. +/- airplanes, and by the end of the run, 1800lb. examples became quite common.
About this time a huge portion of the readers are rolling their eyes, and either ready to shout out how few ounces these things weigh, or point fingers at the manufacturers to suggest their numbers are fraudulent.... whatever.... denial is why 70% of Americans are overweight, and 40% are obese. And the airplanes reflect that same attitude. Grams turn to Ounces turn to Pounds.... simple math.
If it were me, I'd pull that crap job off the airplane and throw it in the air. If it stayed aloft, I'd consider installing it. If it hits the ground, I'd give deeper thought to just how bad I needed it before I put them on 'cause all the cool kids have one'... A few replaced rivets, a few less pounds, and a much cleaner job.
FWIW... mine took that test and hit the ground... Now? ... still sitting on the same shelf I put them on years ago![]()
Take care, Rob
