Backcountry Pilot • Doublers
Doublers
48 postsPage 3 of 31, 2, 3
Re: Doublers
and thank you for the reminder that not all missions are created equally. Because ultimately matching the mission is the first key to happy airplane ownership.
For some reason I was thinking the OP was from TX, so skies never crossed my mind. Now looking at his signature I see it is actually MN, where I imagine skis are probably a staple of airplane ownership #-o
Take care, Rob
Rob offline
Re: Doublers
Ditto if you might put it on floats. Tough to find a place for the ladder when you are surrounded by water.
G2Gorder offline
Seattle float pilot
Re: Doublers
denalipilot wrote:
Rob wrote:
pilotryan wrote: This is why I like to post here. When I go through this area I will make sure that the skin and the doubler get cleaned up and installed properly. What adhesive would you consider using on this?
This suggests that you intend to remove and potentially reinstall this step. You didn't ask for suggestions, but I would like to offer a thought for you to ponder.
Do you intend to install larger tires on this plane at any point? The reason I ask, is that I am 5'6", and have yet to see a need for a step when fueling my 180. Standing on a 29" tires allows me to reach the fuel as easy or easier than a step would.
If it were me, I'd pull that crap job off the airplane and throw it in the air. If it stayed aloft, I'd consider installing it. If it hits the ground, I'd give deeper thought to just how bad I needed it before I put them on 'cause all the cool kids have one'... A few replaced rivets, a few less pounds, and a much cleaner job.
FWIW... mine took that test and hit the ground... Now? ... still sitting on the same shelf I put them on years ago #-o
Take care, Rob
Good general reminder. However, is this thing ever going on skis? if so, they're pretty key.
-DP
Not so sure on the big tires just yet. I'm not an bush-master just yet, but one day :lol: And its an absolutely on the skis! We live on a lake and parking it outside would be cool factor 10!
Rob wrote:and thank you for the reminder that not all missions are created equally. Because ultimately matching the mission is the first key to happy airplane ownership.
Take care, Rob
We still have our place down past San Antonio, all are welcome to visit during the STOL Flyin in Hondo later this year. Hopefully the wagon will be able to participate!
One thing that I did find was this,
That would be a proper step install on a seaplane kit'ed wagon. I don't have that luxury (yet).
pilotryan offline
Aircraft: C185 / C310R
Falcon 900B
Re: Doublers
hotrod180 wrote:….I've never seen fueling steps attached to or aft of the door post......
Well, now I can't say that anymore.
Yesterday I saw a C180 with mini fueling steps that appeared to attach to the door post structure.
Anyone ever see these before? I'm thinking they're a one-off part.
Re: Doublers
So far this year in AK I've seen fueling steps bolted to nearly any spot on Cessnas forward of the door and nearly as high as the fueling handles. Seems like the entire boot cowl is considered fair game for them. A couple planes had multiple, like a ladder.
Re: Doublers
hotrod180 wrote:
hotrod180 wrote:Yesterday I saw a C180 with mini fueling steps that appeared to attach to the door post structure.
How the hell does anyone get a bucking bar back there???????
pilotryan offline
Falcon 900B
Re: Doublers
All the steps I’ve seen have been bolted on, not riveted. Also, there is a hole near the inboard bottom side of each doorpost. You can get to the nuts that hold the lower door hinge through here.
Re: Doublers
pilotryan wrote:Image
They're bolted on.
