Backcountry Pilot • Doubletree Eyeball Firewall Penetrations
7 postsPage 1 of 1
Has anyone used these on there firewall penetrations? I emailed Doubletree to ask about certified use and obviously he has not jumped through the hoopes to get the approval but has several clients who have installed them on certificated aircraft. His opinion is that you can do this one of two ways: 1) If you AI sees this as a major modification then you can go the 337 route (we all know this is getting harder by the day), or 2) If you AI does not classify this as a major modification than you can do it with a logbook entry. I have spoken to my AI and he cannot see how these could be classified "major" as they don't affect flight characteristics, W&B, structure, etc. in any way and they are infinitely more effective than the POS rubber grommet / stainless steel shield that all our birds have currently.
Has anyone here used these and how did you (or your AP/AI) approach it?
Here is a link: http://www.doubleteeproducts.com/products.html
I should note that he has made the steel version to meet the FAR requirements for heat and says if you do use them on certificated aircraft, you need to use the steel version.
Darinh offline
Darin H.
KOGD
Re: Doubletree Eyeball Firewall Penetrations
Wow. How does he even make them for that much? Very cool...I'm replacing my battery cable next spring- I'm going to keep these in mind.
lesuther offline
Yes, they are cool and so much better than the crap that is on all certificated firewalls.
Darinh offline
Darin H.
KOGD
Why don'cha just ask YOUR mech. if he'd sign 'em off or if he's afraid.
NimpoCub offline
NimpoCub wrote:Why don'cha just ask YOUR mech. if he'd sign 'em off or if he's afraid.
Nimpo,
I have and he will sign them off. I was just curious if anyone else has used them.
Darinh offline
Darin H.
KOGD
I've used them and love them!! They're so much better than "stock" stuff. My PMI agreed and neither one of us could come up with any reason that they'd need to be called a major mod.....so in they went and I noted it in the logs.
hardtailjohn offline
Awesome John that is what I was looking for... first hand experience. I have ordered several of them and they should be arriving today.
Darinh offline
Darin H.
KOGD
7 postsPage 1 of 1
