EarthX Batteries wrote:STC's for the use and installation of both 12V…
Bigrenna wrote:EarthX Batteries wrote:STC's for the use and installation of both 12V…
Where’s the 170B???
Dog is my Copilot wrote: I am going to move to the Earth X one day. I am just a little scared of having it mounted up near the firewall. Waiting for more time to pass and no reports of fires. Curious for those that are running Earth X north of the firewall. Have there been any heating problems? ....Would love the weight savings but a melting battery scares me. Curious about PIREPs for those that fly in warm/hot climates with these batteries. Josh
wagonflyer wrote:Has anyone had success in wiring the fault light into a flight display (e.g. G500Txi) rather than a dedicated light?
corefile wrote:I had the earthX on the firewall - the Odyssey would struggle in turning over the XP470 with DER approved 7.5:1 compression pistons (original IO520 ones), if it was anywhere close to 32 degrees - it was very dicey to get it started before draining the battery. The Odyssey looses cranking power quickly as it drains - where as the EarthX keeps full cranking power as it drains. The EarthX is so much more powerful then the Odyssey - it would spin up my XP470 in the cold with no problem.
As for the heating problem - I think everyone unconsciously hears Lithium and right away thinks of the exploding laptop batteries - those are not the same chemical makeup of a LiFePO4 battery - completely different chemical makeup. Also take a look at the date sheets - the Odyssey and the EarthX batteries have the same max temp range. Also - the EarthX has two other safety items - both are required for the installation. 1) it has a safety vent tube 2) it has a fault sensor that is required to be installed to a light on the panel (or to your Main Display). I flew in a lot of 100+ degree weather with a larger then stock displacement engine (more heat) and never had any problems at all - small sample size of that heat (2 summers) - and about 225 hours total with it. But I was very pleased with my EarthX. I did wrap my firewall mounted battery box with heat reflective tape - but that was just out of caution (and I did that when I had my original Odyssey battery) .
Just my 2 cents
PilotPeat wrote:EarthX has an easy to use approved STC list on their website.
It looks like 185 A-F 14v models have STC approval and their list links to which STC bundle you need.
