Part 2! We attached some cylinders. Thanks again Graham for letting me be a part of this (and probably slowing you down with all my questions.)
Fresh piston pins; I've always called them "wrist pins." They are steel with aluminum pressed-in end caps. The pin free-floats in the piston and connecting rod, and if it does make contact with the cylinder wall, that soft aluminum does not gall anything important.
2 attached.
4 attached.
So what happened to get to this point? First we re-torqued all the connecting rod bolts. Then we started with cylinder #5 as recommended by the TCM overhaul manual. There are very specific instructions about the orientation of the piston rings, mainly that the top and 3rd rings should be oriented toward the "top" and the 2nd ring and the oil scraper should be oriented 180 degrees opposite those. We slathered everything in AeroShell mineral oil for assembly and started the insertion.
This tool called a ring compressor makes life very easy.
With the piston mostly inserted into the cylinder bore, we attached it to the rod end with the wrist pin, then compressed the lower ring and pushed it in the rest of the way.
Did you know that these engines use no base gaskets? They have a large O-ring that fits into a chamfered part of the case opening, then it's metal-on-metal at the cylinder base. I thought that was odd, but given that I have only rebuilt 2-stroke engines, maybe it's not? Graham told me a horror story about a fabled mechanic who
did use a base gasket material and the engine blew up after it compressed enough to allow movement of the cylinder on its studs.
Gently slide the cylinder toward the case and onto the stud bolts.
The manual calls for all bolts to be torqued with oil on the threads, so we hit them with a finger dab of oil and started torquing in the very specific cross-sequence called out in the manual. This is done in stages: First to 300 inch-pounds, then to 500 inch-pounds on a second pass. The through-bolts that pass through the case and through the cylinder base are torqued to 700 inch-pounds.
I now must have one of these after using it. It makes my old clicky Craftsman seem lame.
Tada!
Gratuitous starter adapter photo for the hell of it.
