The crank and camshaft had already been installed, and the case halves rejoined. Most of my questions at this point were about the steps to get to this point, with finding a suitable candidate core for overhaul, and how to go about getting stuff yellow-tagged. The inspection for even the slightest pitting and corrosion can disqualify a part from reuse. We tallied up about $24K in parts alone. That's why your engine overhauls are so insanely expensive.
The traditional Continental colors are a thing of beauty.
Freshly manufactured new crankshaft, hungry for oil.
New rods for the 470-R along with fresh Babbitt bearings.
Using a scale, the rods are weight matched into pairs for best horizontally opposed balance.
Wrist deep in some bottom end.
Rods installed and torqued.
Brand new ECI Titans with nickel carbide barrels. They ship with the piston already ringed and installed, but it's important to verify the piston weights and ring part numbers. Too little ring gap and you've got a recipe for cylinder galling.
Pristine head and valves. It'll never look this nice again.
Same for this guy.
