Engine Failure?
Thu Sep 06, 2007 10:01 am
After watching the interview with the pilot I can see how it happened.
As I said earlier my fuel turns clear when I mix 87 mogas with 100 LL. If I put 5 gallons of 87 in with 15 gallons of 100 LL it still looks kind of blue when you sump.
I think the only way that would change would be to move the plane so the fuel got mixed up good.
"S" does happen. RB
6986
I run mainly 87 octane car gas, it's kinda of a yellowish clear, or a clearish yellow. In other words, pretty much colorless. I have used 91 octane just to see if it ran better, never noticed any color with that either.
Eric
10608
Kenny Chapman wrote:always look down the inside of the nozzle for dirt before pumping. Most nozzles are on the outside of the truck and are uncapped and unprotected.
I hadn't been, because I hadn't thought of that, but I will now.
a64pilot offline
1398
Fri Sep 07, 2007 11:16 am
I think I remember that a couple of years ago a fuel company in California (?) bought a bunch of engine overhauls due to contaminating 100LL w/ Jet fuel where the trucks were filled.
No one could tell the difference other than the "slick" feel of the fuel and that it did not evaporate when poured on the ground.
TD
TomD offline
1113
- Aircraft: Maule M5-235C
I always dip my finger into the sample...avgas will evaporate quickly and without residue, jet fuel will leave an oily film on your finger. That, and I always pump my own fuel. It gives me a chance to check the top of the plane.
Hammer offline
2094
