How can we mitigate our exposure to faster aircraft at uncontrolled airports and landing zones?
See and avoid still means look outside.
Radio is an aid to see and avoid not a substitution.
Find big airplane landing lights far out and high.
Lengthen downwind to fall in behind the long final.
Shorten downwind when we do not see (ok and hear) anyone on final.
Communicate as much as practicable.
Ground clutter is real. We see poorly those lower than us. We see better those higher than us.
In high wing raise wing often on base to see and avoid faster airplanes on final.
Make the base to final turn a bit early to avoid the centerline extended until short final.
If startled by potential midair, turn at whatever bank will miss and release back pressure on the stick to unload the wing and use the vertical space available. He is not going to dive on you. Steep turn and descent is fine.
If you happen to work low all day, give way to all other aircraft rather than climb up into traffic.
Helicopter, Ag, and even STOL should work away from normal pattern as much as practicable.
Listen to the small voice in your head. Uncontrolled means advice given but the only rule is see and avoid. Even if there were more rules, legally dead is not good. Uncontrolled is like a football game with no officials. Cooperate and graduate.
What have I missed?
