Here's a picture
Sent from my SM-G870W using Tapatalk
Ok, that is interesting that they yellow walls. The tape lines have definitely retained the white better, it's not just the picture. And any part that is metal has also held the color fine.Rogue wrote:Not sure it helps but the electric ones I've installed yellow walls with certain types of paint others don't for some reason, especially white obviously as well but that's just cheap paint. No experience with the big gas ones but you'd think the plane would need to be pretty close to affect it like that and they're in a lot of hangers. Strange the tape lines held up so well next to the fabric though hey, or is it just the photo? You think maybe it could have something to do with the silver/UV coat maybe?
A1Skinner wrote:Ok, that is interesting that they yellow walls. The tape lines have definitely retained the white better, it's not just the picture. And any part that is metal has also held the color fine.Rogue wrote:Not sure it helps but the electric ones I've installed yellow walls with certain types of paint others don't for some reason, especially white obviously as well but that's just cheap paint. No experience with the big gas ones but you'd think the plane would need to be pretty close to affect it like that and they're in a lot of hangers. Strange the tape lines held up so well next to the fabric though hey, or is it just the photo? You think maybe it could have something to do with the silver/UV coat maybe?
One plane is a Husky with original factory from the early 90s, and the supercub is one that we covered. So I'm pretty sure neither is a silver coat issue.
Battson, very interesting about the fluorescent light. And we are a bit concerned about the fabric degrading at an accelerated rate, which is the reason for my post. Thought I'd see if anyone else has noticed it or not. Seems like not many planes are hangared with those types of heaters though, or so the lack of responses would suggest...
Cary, my plane sits outside as well. Didn't mean anything derogatory by my comment. But I think those types of heaters are less common than other types.Cary wrote:A1Skinner wrote:Ok, that is interesting that they yellow walls. The tape lines have definitely retained the white better, it's not just the picture. And any part that is metal has also held the color fine.Rogue wrote:Not sure it helps but the electric ones I've installed yellow walls with certain types of paint others don't for some reason, especially white obviously as well but that's just cheap paint. No experience with the big gas ones but you'd think the plane would need to be pretty close to affect it like that and they're in a lot of hangers. Strange the tape lines held up so well next to the fabric though hey, or is it just the photo? You think maybe it could have something to do with the silver/UV coat maybe?
Some of us poor folks are lucky to have our airplanes in hangars at all, let alone in heated hangars! I've given some thought to using my tent heater in the hangar--might raise the ambient temp a couple of degrees if the wind doesn't blow too hard.
The hangars are dry. And up in northern BC where the smoke hasn't been terrible until this summer. But they were showing this before that. Lots of other planes we work on that are in other hangars in the area show nothing like this. It really seems specific to the heaters. Like I say it's the only 2 planes we work on that are stored under them.CFOT wrote:The discolored areas you describe are the same areas I see collect dew when I camp out with the plane...makes me think it may have something to do with moisture. Maybe some combination of the moisture byproduct of radiant propane heat, and particulate matter in the air such as lingering ash from all the fires? Seems like there would have to be some sort of temperature variation that would give moisture a chance to condense on the fabric though...unless the humidity created by the heaters is close to saturation.
