jugheadF15 wrote:Put bigger tires on the 170
daedaluscan wrote:My door is a home made bifold. Two panels each made out of 1 1/12" square. (I/8" wall I think) with light angle cross bracing. The upper panel is a little narrower in height than the lower so it cannot overwind. The lower panels have wheels on the outside of the posts which roll up as the door opens. There are five pickup points along the bottom of the door with turnbuckles to adjust tension. They hook up to a counterweight which is a ply box full of scrap steel. A twelve volt ATV winch opens it, with a solar panel on the roof. I also have a boat winch installed if that fails. It has worked well for 9 years so far.
If you are interested I can give you more detail.
Not sure I would do it again, a lot of fiddling and you lose a lot of height - not a problem for me but might be for another owner.
If I take anything away from building a hangar it is listen to the old farts. Build it biggger and wider. Real shortage of hangars that will take a cessna with wing X for example.
