Wed May 13, 2009 10:20 am
As I noted in my earlier post, there are a LOT of variables when you start talking about "wind". Gust factor is a huge one...Crosswind component is also....Flaps or no flaps, or something in between is another.
But, I would again point out that every airplane is a little different. Every WIND condition is a little different as well.
As Skystrider noted, you can listen to the automated observer or even look at the windsock and then be totally surprised at what you actually find when you touch down.
I have seen several times where two wind socks on opposite ends of a runway, are pointed totally opposite directions, and standing straight out.
I tell my students to LOOK AROUND to figure out what the wind is doing. There are lots of wind indicators out there, some of the best being water bodies. Learn to read the water, or effluent from factories, etc to figure out what the winds are doing. If what you SEE disagrees with what the ATIS says, be prepared.
As to specific airplanes, I have to respectfully disagree with Larry on the 180 deal, BUT with a caveat, and that is yet another variable: runway surface.
I've landed a 185 with a 23 knot crosswind at 60 degrees (long story, and it would have been a better idea to go elsewhere). I landed on a gravel runway, and landed full flaps and three point. That is a personal preference of mine, for those airplanes. BUT, the criteria are: Unpaved surface and relatively steady wind. Plant it and stand on the brakes with full back elevator. It works. If the wind were gusty, I'd go somewhere else. The bigger Cessna taildraggers can eat you alive in a gusty crosswind.
But, again, lots of variables, and some of that is personal preference. The majority of my 180 and 185 landings have always been wheel landings, but not in big crosswinds. Some folks will say I'm nuts, but it works.
Again, figure out what YOU are comfortable with, practice and stick to your principles.
