Backcountry Pilot • Float Cleaning / Paint
15 posts • Page 1 of 1
I want to clean up my floats on the Maule (EDO 2448's). I'm considering two options - the first is to clean and polish them and the second is to paint.
If I go the cleaning route, and suggestions for cleaning and polishing the aluminum? They are pretty dirty right now - was sitting in a marina all summer and the water wasn't the cleanest.
If I go the painted route, can I do this myself or does someone certified have to do it? Prep-work procedures? Special paint for floats? There are the remains of "anti-slip" treads on the tops that have worn off over the years - any suggestions on how to remove that?
thx.
garth
gear offline
Re: Float Cleaning / Paint
Garth,
DO NOT strip and polish floats. You will wind up fighting corrosion till the floats dissappear.
You can strip and paint floats yourself if you feel comfortable doing so, and have the equipment and space to do so.
I've used chemical stripper to strip the old paint on three sets of floats. Works good, and there are actually some non toxic strippers out there now, though I don't know if they work as well as the really nasty ones. If your floats are original paint, it won't take much to strip them.
Once stripped, you'll need to acid etch, then alodyne them. The acid etching is a wash coat that you let work for a while, then wash off. Wash THOROUGHLY, though, to ensure that you get it ALL off. The acid reverts all corrosion and etches the surface for paint adhesion.
The alodyne is a wash coat, and is a gold colored watery liquid that is an anti corrosive. Primer goes over the alodyne, again, after the alodyne has been washed thoroughly. Lots of good primers out there these days. Traditionally, zinc chromate primers were used, but again, lots of good paint products available today, including self etching primers. I have no experience with self etching primers, but supposedly they can save the acid etch and alodyne steps. I'd acid etch and alodyne if I were to do it again.
Then, it's time for the paint. I've used laquer, Ditzler Durathane, and Imron. I wouldn't use the epoxies again. Many folks in the industry suggest pretty strongly the use of laquer top coats, for the simple reason that corrosion will show up quick with laquers. The epoxies can hide a lot of corrosion before they start to show bubbling. If you aren't in a very corrosive area, epoxies might work fine. Worked fine on my floats in Fairbanks, a dry climate with fresh water only.
There are dozens of flavors of automotive paints out there that might work just fine as well.
I did all the prep work, and paid a guy to shoot the primer and finish coats. I didn't have a good place to do that, nor did I have all the paint equipment or the skills.
If you feel like you can paint, and you've got the equipment, give it a go. A little less than perfect paint job isn't going to be noticed on floats by most folks.
For "non skid" surface on the decks, I waited till the paint was mostly cured, then painted (with a brush) some pretty thick black paint on top, and used a salt shaker type device to spread ground walnut shell for non skid. Worked great, and lasts longer than you'd think.
Thanks MTV. Was out to the plane today and took a closer look at the floats. I may just opt to cleaning them up.
I put plumbers anti-freeze in the floats this past fall so I decided to take a look in the inspection hole. To my surprise, I found the anti-freeze to be frozen solid :evil: It was about 15F
I looked underneath the floats and saw pink antifreeze that was frozen along the bottom of both floats. My floats did not really leak a lot before so I don't know at this point whether or not it was leaking out old openings or if the freezing has caused new openings. The location of the leaks appear to be at the very bottom of the float where the seam is. I guess I'll find out in the spring how bad it is.
Note to self - never again use the plumbers anti-freeze crap that I bought! :oops:
garth
gear offline
Garth,
I always use RV antifreeze, but you have to really get all the water out of the floats before you add the antifreeze, then you need to cover the floats to prevent any rain getting in, cause any dilution will allow the stuff to freeze.
Don't despair. A vacuum cleaner and a spray bottle of soapy water will find leaks in the spring. Then you reverse the vacuum hose and apply a little gas tank sloshing compound or other sealant to the leaks. Voila!! Tight floats.
If you want a more detailed description, PM me. I'd definitely do this before you put them in the water if they've leaked that much.
Garth,
When you buy the RV anti-freeze, note there are different solutions available (just like "winter" windshield wiper fluid). I have had good luck with the minus -40, as it seems to work well in our climate. Steve
steve offline
Aircraft: 1980 Cessna 185F
The bottle said -40 but I'm sure there was some amount of water in the floats prior to me filling them with the anti-freeze.
Having said that, I have the plane stored indoors so I don't know why I did not just get all the water out of there and leave them dry,..... :oops:
gear offline
Anyone have some good pointers for stripping floats. I'm stripping a set of 1400's in the morning and the temp will be 40-50 degrees tomorrow. This will be my first time stripping floats, and I am hoping they strip better than the rigging did. Any tips appreciated. -Levi
Levi offline
Oldy but a goodie.
Where to find the Edo silver lacquer?
What should I prime with?
Zzz wrote:Oldy but a goodie.
Paint: https://www.aircraftspruce.com/catalog/ ... acquer.php
Prime: https://skygeek.com/akzonobel-446-22-10 ... n-kit.html
This is what the manufacturer (EDO) recommends, and I do also.
Halestorm offline
Aircraft: C-182E Pponk
These folks are also good for float flying supplies. Decades of experience. Their sloshing (sealing) compound is regarded as the standard around here.
https://www.gouletaircraft.com/products
Lacquer paint is the easiest to handle for touch ups. Successive coats soften the existing and melt into it. Really good bonding. That’s what makes it the preferred for floats, because they need frequent touch ups and re-coating. It can be hard to strip, but if the primer used strips easy, then you’ll be OK.
Phone Goulet and ask for silver float lacquer and they’ll know what you want, what you need, and get it to you.
Pinecone offline
Thanks guys.
Will one gallon be enough for a full coat on a set of 2000s?
Zane,
I’d make absolutely certain the floats are tight (don’t leak) BEFORE painting.
You can do that with a vacuum cleaner and some soapy water. Make an adaptor from the vacuum hose to the pump outs. Switch the hose to the discharge side of the vacuum. Put light positive pressure on a compartment with the floats inverted. Then, with a spray bottle, squirt soapy water on all seams, rivets, etc. if anything bubbles, mark with a magic marker, move on till done.
Now you know what needs to be sealed.
Any loose rivets, re-buck them lightly.
Any seam leaks, get some sloshing compound, reverse the vacuum hose to the suction side, and apply a suction to the compartments with leaks. With the vacuum running, LIGHTLY apply some sloshing compound to the outside, where the leaking seam was. Let it be sucked in, than apply a bit more. Clean the excess off the outside of the float. Let the stuff set up, and check to see if leak is fixed. If not, repeat. Or, if it’s on a seam, after first application of sloshing compound, bang the rivets along the seam. Squeezing the seam with set up sloshing compound in the seam should seal it up.
Do NOT use “sloshing compound” literally, sloshing it liberally inside the seams. Sucking small amounts into gaps and letting it set up is the trick.
Then paint. Laborious process, but tight floats are wonderful, and leakers are awful.
asa wrote:http://www.aerocet.com
Hey can you link me to the $5,000 models on there? Can't seem to find em.
On the "right size" airplane, I seriously doubt Aerocet 2200s will outperform a good straight set of EDO 2000s. They have more flotation, but the performance of EDO 2000s is amazing.
And, as Zane noted, there is a "slight" price delta there.
