Zane wrote:There is a story out there about a 170 that lost a single blade, which resulted in the entire engine/mount/cowling departing the aircraft. The pilot deadsticked it, flat firewall straight ahead, to safety. Aviator myth or true story?
The balance had to have been obscenely out of wack.
185 Bushbird wrote:This is a interesting one that a plane will not fly with a engine attatched! I bought this 172 after the mid air, insurance bid buyout. It had no engine, a slice in the left boot cowl from the prop hit plus left wing strut almost cut in half, otherwise fuselage was in good shape other than the brown streaks on pilot & co-pilot seats!. I had it rebuilt ,float kit, LR fuel, 180hp pen yan conversion, new floats, it resides MN on floats now.
NTSB Identification: FTW90FA151A.
The docket is stored on NTSB microfiche number 44583.
Accident occurred Tuesday, August 07, 1990 in ELMENDORF, TX
Probable Cause Approval Date: 5/3/1993
Aircraft: CESSNA 172M, registration: N1466V
Injuries: 1 Minor, 3 Uninjured.
A USAF T-38 & A CESSNA 172 COLLIDED AT 4200' MSL. DRG IMPACT, THE VERTICAL STABILIZER OF THE T-38 STRUCK THE RGT SIDE OF THE 172'S ENG. THE ENG SEPD & THE 172 PLTS LNDD ON A ROAD. THE T-38 DSCNDD OUT OF CTL, BUT THE T-38 PLTS EJECTED SAFELY. BFR IMPACT, THE STUDENT IN THE 172 (WITH A VISION RESTRICTING DEVICE) & HIS INSTRUCTOR (CFI) WERE PRACTICING AIR WORK MNVRS. THE TANDEM SEAT T-38A (WITH AN INSTRUCTOR PLT IN THE BACK SEAT & A RATED PLT IN THE FNT SEAT) WERE BEING VECTORED FOR AN ILS RWY 33 APCH TO KELLY AFB. THE T-38'S SPD WAS ABOUT 330 KTS; THE SPD LIMITATION OF 250 KTS HAD BEEN WAIVED FOR T-38 ACFT, DUE TO THE ACFT'S LACK OF CONTROLLABILITY AT THE LOWER SPD. THE 172 WAS EQUIPPED WITH A TRANSPONDER, BUT IT WAS NOT EQUIPPED WITH MODE C. THE T-38 WAS EQUIPPED WITH A MODE C TRANSPONDER. BOTH ACFT WERE IN RADIO CTC WITH THE SAN ANTONIO SOUTH DEP CTLR, BUT ABT 3 MIN BFR THE COLLISION, RADAR SVC WITH THE 172 HAD BEEN TRMTD.
s:
Not a hard call to makeLittlecub wrote:If your more likely to Die by stayin' put than gettin' out, that is a call to make
