I have an EI FP-5L fuel computer which is pretty accurate, which tells me that I consistently burn 9.8 gph on most legs of a cross country flight. My airplane holds 52 gallons, 42 usable in all flight regimens and 47 usable straight and level. Once in 11 years I've run 40 gallons out of it (way too squeaky) and a couple of times I've run 37 out, leaving a half hour reserve in all regimens, an hour straight and level (not my preference). Usually my bladder gives out before then, so more typically I use right around 30.
I programmed that 9.8 gph cruise figure into my Foreflight program, but I haven't bothered to input climb and descent fuel burn. I figure it uses more going up and less going down, and that works out pretty evenly--and it really does. It doesn't burn enough taxiing to worry about, even on long taxis. And guess what? The figure that FF tells me I'll use, using only that 9.8 gph cruise figure but without the micrometer method of exact climb usage and exact descent usage and exact taxi usage, comes out really close every time. For flight planning purposes, and leaving an adequate reserve, it's just not necessary to be more exact.
On a long cross country with several fuel stops, it's easy to put together several flight plans on FF. That's probably a good idea, anyway, IFR or VFR. Wouldn't that tell you what you're wanting to know?
