mtv wrote:What year, early or late?
"Early or late?"
Cessna made 4 sets of gear for the 180/185, -1,2 -3,4 -5,6 and -7,8.
-1,2 was used on the very very early birds, using the same geometry as the 170, but with a different spring rate. They are also a bit thicker and a bit more robust. For example, you would not want to run large bushwheels on the early C170 legs as they are just not strong enough in the ankles.
-1,2 were ONLY used up until S/N 31206, which is a 54'.
-3, 4 replaced -1,2 because Cessna realized Skywagons were nosing over and moved the axle from 22" to 18". On the 180, both -3,4 (standard duty) and -5,6 (heavy duty) were used up until S/N 18051775, and then -7,8 from there. The last iteration -7,8 were used on the late model 180s and 185. For some reason, some outfits are using the word "light duty" to describe -3,4 but thats misleading. Something is only light duty if you use it in the wrong application. LOL. The word “light duty” infers that something is inferior and implies that “heavy duty“ is much more betterer. The Internet is great, but in lots of ways, it’s not. Heavy duty on a 170 in most cases is much more worserer.
IMO, -5,6 are WAY too heavy for a 170B... not to mention the -7,8. What matters is spring rate, and where the axles are with respect to the datum. Folks should choose gear based on the aircraft weight. Know the weight, then pick the proper spring rate commensurate with the median operating weight. IOW, you don't want to toss gear on a bird with a 2200lb GW that was meant for one with a 3600 lb GW. The energy that is being vectored into the airframe that is no longer being dampend by the gear as it was intended, probably isn’t doing the good things for the 80 year old airframe.
Looks like Roman has the standard duty C180 legs, which are one of the suitable choices, along with the -1,2 to use on the Super 170B. Difference being spring rate, physical weight (-1,2 are like 1.5lbs lighter ea) and wheels forward" or "wheels aft."
Hope this helps...
Greg-
