Backcountry Pilot • FS: McCauley C58 prop and spinner ($1000)
3 posts • Page 1 of 1
Cleaning out the hangar and trying to sell a D2A34C58-NO prop (blade PN: S-90AT-4) and/or spinner + bulkhead (PN 0752042k201 and 072041-1) off of a C-185. Prop overhauled in April 2015 by Sensenich Propeller Service in GA. TTSN is unknown, prop was removed from service in Dec 2018 due to leaking hub at 470 hrs SMOH. I used the leak as an "excuse" to upgrade to a MT prop, so everything is sold as is and the hub has not been inspected to determine the cause of the leak. After sitting on the shelf for a few years it's time to clean out the surplus parts.
The blade length (as measured in the picture) is to the blade root since I didn't have a long enough tape measure to the full diameter. The dye leaked out from the seal and the dye that can be seen near the prop bolts is run-off from the seal area from sitting bolts down.
Spinner was painted, but currently polished and has a small dent near the tip. It was hard to capture in the photo, but the dent is towards the right side of the window reflection that can be seen on the spinner just to the left of the tip. The bulkhead lugs are not pictured, but are included.
Eric
fredy offline
Re: FS: McCauley C58 prop and spinner ($1000)
Sent you a DM, Fredy.
upnorth180 offline
Aircraft: '54 C180
'65 C185
‘54 BE18
BE18 (floats)
I know this is an old post, but wondering if the prop, spinner and backplate are still available? Mainly interested in the the spinner and backplate! If not, I'm looking for a backplate and spinner for an O-470-U/C180K application.
Thanks in advance!
Az182 offline
