3000 lb gross weight, 1300 lb useful load, TTSN:510
48 inches wide at hips, plexiglass gull wing doors
D&E wings 66 inch cord, wing span 39 feet
74 us gal. Max endurance 12 hours with LOP
Lycon overhauled Lycoming IO-360-C4P polished/ported 10.5:1 pistons dyno @232 hp SMOH:130
Dual Emag Air Pmags with internal alternators
Skytec light weight starter, Plane Power 60 AMP alternator
Earth ETX 680 Lithium LiFePO4 Battery, 680 AMPS PCA
E-Z HEAT 440 Engine heater
MT 3 blade constant speed prop MTV-9-B/200-52 with nickel edges
Grove landing gear and axles
Cleveland 185 double puck wheels brakes, parking brake
Goodyear 26” tires
Removable rear seats & cargo tie downs
Dual Fuel tanker drains
Advanced Flight Systems EFIS with PFD, fuel computer, AoA, engine monitor, checklists, maintenance checklist etc.
Starter solenoid freeze detection, Battery Fault, Alternator Fault
Digital fuel gauges calibrated for ground & air
Garmin GTR 200 radio & intercom- frequency feed from 396
396 Garmin GPS panel mount
10" Tablet screen panel mount
uAvionics Tailx ADSB beacon with satellite compatible diversity antennae
uAvionics AV-20S – control head with OAT, TAS, timers, AoA, AI
Electric trim
406 ELT with GPS
Smartphone charging pad
LEMO pilot headset jack
Dual Lightspeed 2 headsets
Strobes & Wigwag landing lights
