Trimetric wrote:Interesting discussions here. I have a question as a new IA..
I was looking at a 182 for sale then Googled the N number and found an NTSB report showing the aircraft had been substantially damaged in an accident over 40 years ago.
Upon contacting the owner, he said he was unaware of the damage and there was nothing in the logs and no 337 for a major repair.
So the question is, where does that leave the aircraft/owner? Can the aircraft be made legally airworthy?
My opinion as an IA is that the aircraft is unairworthy since there's no way to verify it's in compliance with its type certificate (14CFR 3, definition of airworthy) due to the fact that no one knows what was damaged, how it was repaired, and with what materials/data.
So how does one move forward with such an aircraft? Is there any process for making it legally airworthy?
Thanks..
P.S. Please keep in mind here we're talking about legally airworthy and not flight worthy.
* I was not the one to bring this back from the dead
Per the question, what logs do you even need to keep for an airplane?
Prove it’s airworthy, ok, so I got my annual, show compliance with ADs, pitot static/xpdr/elt/100hr as req.
Where does it state you even need to keep your old logs? Obviously it helps with the planes value and all, but much like a pilot logbook there isn’t a ton that needs to be legally kept compared to what most keep
“ § 91.417 Maintenance records.
(a) Except for work performed in accordance with §§ 91.411 and 91.413, each registered owner or operator shall keep the following records for the periods specified in paragraph (b) of this section:
(1) Records of the maintenance, preventive maintenance, and alteration and records of the 100-hour, annual, progressive, and other required or approved inspections, as appropriate, for each aircraft (including the airframe) and each engine, propeller, rotor, and appliance of an aircraft. The records must include—
(i) A description (or reference to data acceptable to the Administrator) of the work performed; and
(ii) The date of completion of the work performed; and
(iii) The signature, and certificate number of the person approving the aircraft for return to service.
(2) Records containing the following information:
(i) The total time in service of the airframe, each engine, each propeller, and each rotor.
(ii) The current status of life-limited parts of each airframe, engine, propeller, rotor, and appliance.
(iii) The time since last overhaul of all items installed on the aircraft which are required to be overhauled on a specified time basis.
(iv) The current inspection status of the aircraft, including the time since the last inspection required by the inspection program under which the aircraft and its appliances are maintained.
(v) The current status of applicable airworthiness directives (AD) and safety directives including, for each, the method of compliance, the AD or safety directive number and revision date. If the AD or safety directive involves recurring action, the time and date when the next action is required.
(vi) Copies of the forms prescribed by § 43.9(d) of this chapter for each major alteration to the airframe and currently installed engines, rotors, propellers, and appliances.
(b) The owner or operator shall retain the following records for the periods prescribed:
(1) The records specified in paragraph (a)(1) of this section shall be retained until the work is repeated or superseded by other work or for 1 year after the work is performed.
(2) The records specified in paragraph (a)(2) of this section shall be retained and transferred with the aircraft at the time the aircraft is sold.
(3) A list of defects furnished to a registered owner or operator under § 43.11 of this chapter shall be retained until the defects are repaired and the aircraft is approved for return to service.
(c) The owner or operator shall make all maintenance records required to be kept by this section available for inspection by the Administrator or any authorized representative of the National Transportation Safety Board (NTSB). In addition, the owner or operator shall present Form 337 described in paragraph (d) of this section for inspection upon request of any law enforcement officer.
(d) When a fuel tank is installed within the passenger compartment or a baggage compartment pursuant to part 43 of this chapter, a copy of FAA Form 337 shall be kept on board the modified aircraft by the owner or operator.” If the plane comes with the above records it’s 100% airworthy
The damage reported by the NTSB, doesn’t mean much in this regard.
Lots of work could have been done that wouldn’t be required to be retained 40yrs later.
I know of planes with very old damage history. They were fixed, old logs lost, and went through a full import into another country, and even were re imported back into the US without issue
If you haven’t already I’d also request the FAA CD for the plane
https://aircraft.faa.gov/e.gov/ND/
