Backcountry Pilot • Fuel Bladder Issues and Recommended Suppliers
7 posts • Page 1 of 1
Hi everyone!
Am having small black plastic-looking flakes coming out of my 1957 Cessna 180 tank. I tried flushing the tank out when it was de-fueled during a recent wt/balance check, but am still getting debris coming out. I think this is the tank deteriorating and parts are coming off. Does that sound about right? Pics included below.
We bought replacement tanks and installed them in 2014. But, I think that a previous pilot left the airplane without fuel in hot/dry conditions for several months and think that may be the issue.
Can anyone please recommend a good supplier for new fuel bladders? Thanks in advance!
AlaskAfricaPilot offline
Aircraft: C180
Re: Fuel Bladder Issues and Recommended Suppliers
I just replaced both of mine (1975 180J).
My mechanic found them at a good price and with good service from Floats and Fuel Cells, Memphis, TN.
kg offline
Aircraft: Cessna 180J
I have Eagle from Eagle River Wisconsin in my 1954 180. They use nitrile rubber that is good for ethanol too. Nipple placement would be my only gripe since I had to send one back. It would not work without cutting the outlet hole in the original butt rib bigger and I didn't want to cut something original from the factory.
I’ve worked directly with hartwig for 20 years now for fuel cells, always had a good experience there. Good idea to get their stc’d eagle fuel drains while you’re at it, they’re corrosion resistant and can be rebuilt in situ.
Halestorm offline
Aircraft: C-182E Pponk
I'll second Hartwig. Bought lots of bladders from them and always had good luck with them.
I’d recommend Eagle. I’ve purchased 4 tanks from Hartwig.
slow18 offline
My bladders were not that color that looks more like rubber, fuel line or gasket type rubber.
Glidergeek offline
Aircraft: 1968 P206C
DG 400
