Pusher wrote:In my opinion running wing tanks in either left or right instead of both is dangerous. I know someone who flew a C172 and missed some points on the checklist on run-up. Took off with the fuel sector in left and flew until he ran out of fuel in the left tank and the engine quit. Selected the fuel selector to both, engine did not restart, ditched into a lake and unfortunately drowned. Personally I like a fuel plumbing design where two wing tanks are connected directly via a fuel line, balance with gravity and then each have an additional fuel line going to the fuel selector valve. The reason why the fuel selector is switched between left and right on run-up is to check if the fuel pick-up of the associate tank is obstructed or plugged. There is absolutely no reason to run on one wing tank only.
courierguy wrote:Obsessing over keeping both wing tanks somewhat even is busy work.
Pusher wrote:MTV
The facts are when the aircraft was brought back to the surface:
- left tank was empty
- fuel selector in both
- right tank was full
- no obstruction in right pick up or fuel line
- engine started right up
That was the conclusion of the Investigator. Also there were 2 passengers on board who survived and stated that this was what happened.
Btw I was not talking about fuel tank systems with aux tanks.
