Why would you want to drive it from the G5 when you can simply hook up the RS232 wire from a GPS? Or are you looking to use the G5 as a DG to hold the heading? The G5 is hooked to the gdl 29, which is hooked to a gps(how I understand the connection). But if you just have a GPS antenna hooked to a G5, not sure I you need a GDL29. But also not sure if you can use it for GPS steering then. Will be following this as I'll have the same/similar setup in my 206...gypsywagon wrote:I have seen that the new G5 is going to have GPS steering but my question is will you be able to role steer specifically a Trio Pro auto pilot from the G5 HSI if new headings are given by air traffic control or will it only follow the GPS course? I think the detail is in the G5 uses a GAD 29 data bus to drive for the roll steering but the Trio Pro has an ARINC 429 data bus. Or do I just not know what I am talking about. My question is can I drive the Trio Pro auto pilot with the G5 or just the GPS?
GAD is what I meant. But do you still have to have a GPS hooked up to the whole shebang? In that case, I think it's still easier to just hook it up direct to the Trio using the RS 232 or Arinc 429 output...jaudette wrote:If you buy the GAD 29B it will support the following autopilots: Century II/III; IV (AC); IV (DC); 21/31/41; and 2000; Cessna 400B and 300 IFCS/400 IFCS; Honeywell (Bendix King) KAP 100/150/200; KFC 150/200; KAP 140; and KFC 225; S-TEC 20/30/40/50/55/60-1/60-2/65; 60 PSS; and 55X.
More to come I hope. The newer certified Autopilots will be a long time out I suppose... Why help the competition...
Jim
A1Skinner wrote:GAD is what I meant. But do you still have to have a GPS hooked up to the whole shebang? In that case, I think it's still easier to just hook it up direct to the Trio using the RS 232 or Arinc 429 output...jaudette wrote:If you buy the GAD 29B it will support the following autopilots: Century II/III; IV (AC); IV (DC); 21/31/41; and 2000; Cessna 400B and 300 IFCS/400 IFCS; Honeywell (Bendix King) KAP 100/150/200; KFC 150/200; KAP 140; and KFC 225; S-TEC 20/30/40/50/55/60-1/60-2/65; 60 PSS; and 55X.
Jim
Yes you can use it as an HSI. You need the GMU11, GAD29, and hooked to a GPS.Mapleflt wrote:If a single G5 EADI is installed to replace steam gauges can it be "reverted" to the EHSI and display a gps track ? What supporting equipment would be required to accomplish this in the simplest manor ?
Mapleflt
The nice thing with the G5 is that you have airspeed and altitude right on it as well. I'm just putting one in as a DG on a supercub right now.Mapleflt wrote:Thanks for the intel, I’m really trying to craft a 21 century “needle, ball & airspeed”panel, with some enhancements !!
A1Skinner wrote:The garmin 660s are very nice. I like my 796 better simply for the XM radio, but the dual sattelite glonass/GPS of the 660 is nice.
jaudette wrote:A1Skinner wrote:The garmin 660s are very nice. I like my 796 better simply for the XM radio, but the dual sattelite glonass/GPS of the 660 is nice.
The 796 and the GDL39-3d is one of the best combo's I've flown behind. It does everything!
A1Skinner wrote:jaudette wrote:A1Skinner wrote:The garmin 660s are very nice. I like my 796 better simply for the XM radio, but the dual sattelite glonass/GPS of the 660 is nice.
Ok. This is most likely what my 206 will end up with. What does th GDL39-3d add for function? ADS-B?
jaudette wrote:A1Skinner wrote:jaudette wrote:[quote="A1Skinner"]The garmin 660s are very nice. I like my 796 better simply for the XM radio, but the dual sattelite glonass/GPS of the 660 is nice.
gypsywagon wrote:...my question is will you be able to role steer specifically a Trio Pro auto pilot
