Backcountry Pilot • Garmin GI 275 series flight & engine instruments intro'd
23 postsPage 2 of 21, 2
Re: Garmin GI 275 series flight & engine instruments intro'd
C180_guy wrote:
kg wrote:One advantage I see is the ability to replace a round dial without carving out a new panel with rectangular holes.
Right - that is the AV-30. Two AV-30s cost $4K, which is the price of just one of those garmin things
Yes, but keep in mind you can buy the Garmin now and install it in a massive range of aircraft, including those over 6,000lb. Once installed it will work, and it will work well. If there is a fault, you'll have exceptionally good customer service and support with little downtime. There will be a steady stream of software updates and additional features. And importantly, to me, in 5+ years time when the warranty has long expired, it will still have a flat rate repair option at probably less than $2k to swap out with an overhauled unit
No doubt it's not the cheapest unit out there, but what a feature set. The ability to drive a legacy autopilot will be a big selling point
As others have mentioned, the target market will jump on these very quickly. I'm placing orders for stock units now
:D :D
onefitty offline
You can also buy an Aspen E5 now at half the price with an increased feature set. Epic fail by garmin and my motto remains 'never garmin'
C180_guy offline
I've used Garmin products in the past; no real issues however I prefer "flexibility", Garmin is a bit to proprietary for my liking
