Garmin Guru
Just wondering if there's a Garmin Guru in the BCP ranks. I purchased a previously enjoyed GNC250 that I've installed for basic nav/comm requirements. I sourced a new blank nav data card directly from Jeppesen and successfully uploaded a new Alaskan/Canada navigation database. I now seeing on start up the following message "route WPT locked" which according to the manual is a result of a "user defined" waypoint that is no longer in the new database.
So here's the question, is there a way to excute some sort of master reset that would effectively scrub all previous user defined waypoints and let me start fresh ?
Thank you in advance
2324
I had a 300xl that had the same issue, even after having it redone at Garmin. I had to go in and find the user WPTs and delete each one individually. Was a little tricky to ferret each one out. But seemed to work.
Badstick offline
16
Garmin support has "schooled" me on how to do a master reset but if that doesn't work I'll giving your trick a go, thanks
2324
Wed Apr 27, 2022 12:35 pm
If it works care to share?
Badstick offline
16
Absolutely, apparently a "master reset" is done by holding the CSR button down while powering up the unit, then when the unit does power up for a further 10 seconds thereafter.
2324
Badstick offline
16
