Not airborne yet but getting closer.
Crazy talk Bryce. You have to listen to us!Mapleflt wrote:Just because and it's mine so I get to call the shots.
Mapleflt wrote:A bit of redundancy I suppose you may notice I also have installed two direct reading mechanical gauges, oil pressure and a tach
.hotrod180 wrote:If / when I get a digital oil temp / presusre instrument,
I plan on keeping the mechanical oil pressure gauge.
Just in case.
mtv wrote:I’ve been running all digital engine gauges for quite a few years on several planes. Never had a problem. That statement probably jinxed me, though….
That said, in past, I’ve had an oil pressure gauge go south, an ammeter crap out and two mechanical tachs give up. So, choose your flavor. But, at least in the US, a failed instrument still grounds the plane, at least till a mechanic disables and placards it.
I for one, like digital engine gauges.
Mapleflt wrote:mtv wrote:I’ve been running all digital engine gauges for quite a few years on several planes. Never had a problem. That statement probably jinxed me, though….
I haven't any particular gripe against digital gauges other then I'm forced to stare at them at work. So wanted to avoid them somewhat when I'm at play, I'm on a "no magenta" mission.
mtv wrote:Mapleflt wrote:mtv wrote:I’ve been running all digital engine gauges for quite a few years on several planes. Never had a problem. That statement probably jinxed me, though….
So, all EI Digital engine instruments AND a digital engine monitor?Hey, it's YOUR airplane and your instrument array, so as long as you're happy, it's all good. And, that instrument panel looks REALLY nice to my eye.
Hope you're flying soon.
mtv wrote: Why keep all those EI guages with the engine monitor? Otherwise, looks great. MTV
Mapleflt wrote:It’s an EDM350; very basic, will serve my needs well enough and permitted under an Canadian OM C of A
