GNW 430 WAAS Comm Static
The main radio in my Maule is part of my GNS 430 WAAS setup. Lately I've been getting constant static on the 430's comm radio when nobody is talking. If you push the volume button to check the volume, you will get that same stream of static - I think it is the carrier wave form or something like that. Well, I'm not pushing the volume button and the static is loud and clear ALL THE TIME. I'm starting to go a bit crazy. Is this a repairable condition, or am I looking at a new box in my panel?
976
- Aircraft: MX7-180C
-0-
dogpilot on Thu Aug 06, 2020 12:41 am, edited 1 time in total.
dogpilot offline
- Took ball and went home
902
- Aircraft: Cessna 206H Amphib, Caravan 675 Amphib
Sun Jul 21, 2019 10:00 pm
Thanks dogpilot, I'll see if I can run the reset gauntlet. The problem I'm having is intermittent. The static comes on strong at random intervals and stays on for 3-5 minutes and then goes away for 30 seconds before returning for another 3-5 minutes. That intermittent behavior makes me suspect it isn't just a squelch setting, but that's certainly a good place to start my troubleshooting. The noise level in the cockpit doesn't seem to have an effect one way or the other. It's immensely frustrating and distracting. And it is a GNS430 WAAS unit, my fingers are just too big to hit the S and not the W key on my keyboard.
976
Do you get the static with the engine not running?
a3holerman on Tue Jul 23, 2019 1:14 am, edited 1 time in total.
a3holerman offline
278
- Aircraft: Cessna 185
Have you recently added LED lights? Are you running a USB charger?
TradeCraft offline
364
