Backcountry Pilot • Go Ahead... MAKE MY DAY !!!
28 postsPage 2 of 21, 2
Re: Go Ahead... MAKE MY DAY !!!
The proof is in the pudding. Shoulder harnesses have been available for a long time, they're cheap, and the feds have made it very easy to install them with very little regulation. Yet a lot of airplane owners still have not put two and two together to put them in.
All the ones I know, who walked from a wreck wishing they had worn a shoulder harness, promise on their grandmothers good name to install one... or at least think about upgrading to a multi point harness system. A BAS system is not the cheapest addition but I feel that the restraint systems we use and have been using for years are a joke. At least two close friends of mine are dead, because their harness system allowed them, or forced them to chose between two things: Actual restraint, or aircraft control.
Shorter people like me have to have the shoulder harness lose in order to get to the flap handle or water rudders. Since accidental gear down water landings are still quite common, leading to drowning and/ or smashed in faces (unconscious pilots don't normally get out alive) there is certainly reason to act.
jjbaker offline
JJ Please contact me via private message or off-forum e-mail via the website mentioned below. The very valid points you just made are the reason I invested a year of my life in certifying an STC upgrade to correct this exact situation. I have read about very well known pilots in AK and elsewhere who were needlessly lost because of this. Bottom line is that if you are interested in safety on this specific subject, we should talk.
One of my very first purchases after I bought my airplane was a set of BAS harnesses. I had not yet had them installed when I threw a rod and landed in a field--fortunately I did not need them then. They were installed during the same time that the new engine and a number of other modifications were made, and I like them very much. They are hardly noticeable while on, and they allow me to reach for whatever I need to, without hindrance.
Cary wrote: They are hardly noticeable while on, and they allow me to reach for whatever I need to, without hindrance.
If you have one of the airplanes that are certified for a flap handle extension device, I'll bet you a a steak dinner at Outback Steakhouse that it makes a significant improvement, with or without the BAS.
What kinda airplane are you flying?
EZ - you mean that pic of the cute girl in your avatar isn't you? :cry:
Guess I don't need to be nice to you any more when repyling to your posts. :D
nmflyguy offline
Please let me hi jack the tread for a moment.
What are your thoughts on the single factory inertia shoulder belt? 3 point system. I have a 2000 Maule with that style. My thought is better than nothing but not as good as a 4 point BAS system.
Now my thoughts on The EZ Flap. I bought one last year at Austin. Been to busy to put it on. I finally put it on last week. I wouldn't fly without one now that I have used it.
I have one small issue. I can't make the pull to the last notch from 40 to 48* Not a big deal. Once I am at 40* I simply grab the handle in the stock position for the last 8* pull.
I emphasize, I wouldn't fly without one now that I have used it.
Thank you sincerely Rob.
You figured it out, it was purposely designed to allow you to use the stock aircraft flap handle any time that it becomes more convenient, specifically the last notch on the Maule and the 30 and 40 notch on Cessnas
nmflyguy wrote:EZ - you mean that pic of the cute girl in your avatar isn't you? :cry:
No, that girl is the widow of a close friend of mine who passed away in a Lancair crash a couple of years ago. She's a student pilot (in an F-33 Bonanza that she and her husband owned). She's way too Hollywood for anyone on this forum, even me =P~
