Hi Folks-
Just got a GoPro Hero 5 Black for Christmas. What is the best editing software available?? I am not a photo guru so I would prefer something simple.
Safe Flying - Dave
asa wrote:I didn't see it listed in the other thread, but I recently got DaVinci Resolve 14 for something work related. It's free and downloadable at the link below. It's many steps above GoPro Studio in terms of capability but also complexity. One of those programs where you ask yourself how they could just give it away for free. A big monitor helps, it's a pretty detailed interface. However, GoPro Studio will probably get you what you need and it's extremely simple and easy to use, just less capability.
https://www.blackmagicdesign.com/produc ... nciresolve
Zzz wrote:asa wrote:I didn't see it listed in the other thread, but I recently got DaVinci Resolve 14 for something work related. It's free and downloadable at the link below. It's many steps above GoPro Studio in terms of capability but also complexity. One of those programs where you ask yourself how they could just give it away for free. A big monitor helps, it's a pretty detailed interface. However, GoPro Studio will probably get you what you need and it's extremely simple and easy to use, just less capability.
Really? It's the first thing I mentioned.![]()
Resolve is cool but it's a freemium type of thing. Many features require the upgrade.
Dave: "best" and "simple" usually don't intersect with video editing software. There's really no substitute for spending some time learning how to use it. Luckily there are many tutorials on Youtube for the popular products.
asa wrote:Sorry, I stopped reading your posts a while ago.
colopilot wrote:I spent a while in Premier, and less time than I maybe should have in Davinci trying to get a multicam sequence to sync properly without significant marking and tweaking. If you have cameras which save true timecode it's a no brainer, but GoPros (at least the Session's I recorded with) aren't that cool. You can get a backpack for a few hundred bucks per cam which gives sync'd timecode and remote control, but ... $$$.
Then I downloaded a trial of Final Cut Pro X last night and was playing with that. First, I tried audio sync of the clips. It took bloody forever, however at least realized I had multiple cameras, and made the attempt to sequence them. It failed, but got further than the other two before they gave up. Then I noticed it has one very interesting multicam feature the others don't: Sync by content creation time. As long as the time is set right in the cameras, the video should line up. The only other thing necessary was to set the camera angle tag for each clip (can also use cam name, but it will key from angle tag first). Then creating a completely and properly sync'd multicam file was instant. From here I just need to cut them in/out and grab the best shots. Film at 11.
I expected more from Premier honestly. I get it as part of my CC subscription I have for Photoshop/Illustrator/etc, but for as much as they tout Premier I thought it should be able to do what FCPX did. My downfall with Premier is that I don't have a good audio signal to line them up across all cameras (I should have clapped or something), and do not wish to spend a bunch of time marking every clip just to tell it A comes before B. FCPX made it as simple as I wanted it to be. I'll still play with Premier and Davinci a little more and see if I'm just missing an easy way to do this, but barring that I may just drop the cash on FCPX and quit wasting time coddling annoying app design. It's a pro level tool and will do anything the others will, especially for my uses.
NOW, if I just had a single cam then almost anything would work. You get more editing and cleanup features from pro tools and Premier would be it for me at that point. For multiple camera angles however so far I am liking the Apple software better just for time saved.
Zzz wrote:Is the video posted? Curious to see it.
I think you're making it too difficult.
If you want to spoof sync, just put one video track on top of the other using 2 video tracks. Find some common event where you can sync the two long clips. Then, use the razor tool to chop up the track on top into logical segments, opening holes as it were in the top track for the track underneath to appear. If you just adjust the frame handles on the end, but don't actually move the clip, your sync will be maintained.
That's not Premiere specific, just a technique for any non-linear editing tool that supports stacked video tracks.
Timecode is nice, but it also is a little rigid. I use audio from other planes, places, times. I think Premiere is awesome for allowing you to quickly "paint" like that.
Zzz wrote:Creation timestamp though is meaningless. It's only the time the file was written to the file system.
True timecode like SMPTE is encoded with the media and is absolute, like the Unix epoch. It's a feature that's just not worth adding to consumer grade cameras like GoPros. Maybe some have it and I don't know? 5 minutes pass. Whoah, just Googled this: https://gopro.com/news/getting-syncd-wi ... de-systems
Barnstormer wrote:iMovie is all I use. The only thing I can’t do with it is a movie within a movie.
SkySteve wrote:Barnstormer wrote:iMovie is all I use. The only thing I can’t do with it is a movie within a movie.
Here is a movie in a movie using iMovie
Barnstormer wrote:SkySteve wrote:Barnstormer wrote:iMovie is all I use. The only thing I can’t do with it is a movie within a movie.
Pray tell where?
