Background – as some of you may remember, my 172 has had the Sportsman STOL system applied and has 8.50 x 6 tires on it.
Been working the bottom of the stall envelope and decided to put it to use when landing at KLAW this afternoon. Flew the pattern at 70 downwind with 10 degrees of flaps, 60 with 20 degrees of flaps on base, and 50 on final. Pitching for 50 on final was definitely different from what I have done in the past. As I crossed the threshold of the runway, I pulled out all of the power and got ready to round out and flare, I started getting “weird” feelings from the peripheral “cues”.
I felt that my approach angle was too high and that I was really going to have an “arrival” with this landing and I started to cringe at what I was doing to my poor plane. The touchdown was a little firm, but there was no bounce and the gear didn’t even seem to flex badly. Sort of like doing a real short field – I did make the first turn off with no braking.
Sadly, I didn’t have time then to do a go around and try for the higher speeds that I’m used to using but if the weather cooperates tomorrow, I plan to spend some time in the pattern looking for some answers.
Anyone else have something like this happen when playing with the bottom end of the STOL kit? DO I just need to retrain the seat of my pants?
Don
