Fri Feb 17, 2006 12:02 pm
CAB:
I got my PPL in a PA-18-150 Super Cub on February 2, 2002. I now own a Hughes 269C and have about 75 hours in a Schweizer 300CB out of Helicopter Adventures in Concord, CA. Still haven't gotten the rating, mainly because it is hard to consistently get to the lessons (damn work keeps getting in the way). When the weather is good, though, it is fun flying the Cub to Concord, flying the helicopter and then flying the Cub back to Santa Rosa.
Since I actually was dumb enough to purchase a 269C, and have Hillsboro Aviation completely rebuild it (it is a 1981) and since I have been taking lessons for about three years, I do have some observations.
First, the helicopters are damned expensive. Even the tiniest part is generally wildly expensive. I really don't know yet, but I think the regular maintenance will be relatively OK.
Second, they are really fun to fly and lots of altitude restrictions that apply to fixed wing don't apply to helicopters. You can safely do things and go places that I wouldn't even dream of in the Cub.
Third, flying the helicopter (at least after the initial shock of how sensitive the controls are and how every input varies the other inputs) is relatively easy. The emergency maneuvers, however, consume most of your training and are the real five ticket rides. Everyone ought to go out at least once and rent a helicopter and a good instructer and go through an autorotation. Helicopters do have lots more aerodynamic things that can sneak up on you than in airplanes: settling with power, dynamic roll over, retreating blade stall, etc., etc.
Fourth, you don't ever really get to rest in a helicopter. You have to fly it all the time. Turning on carb heat (in the non-fuel injected models) means you have to let go of something important, the collective. Actually doing anything like changing radio frequencies means you have to momentarily let go of the collective. Reading a chart? Forget it. I flew a Schweizer from Reno/Stead (4SD) to Santa Rosa (KSTS) last year via Truckee and Auburn, about 160 NM, and after the 4.6 hour flight, fun as it was, you were done for the day.
Fifth, the helicopter training forces you do be a much better pilot. You absolutely have to be more aware of what's going on all the time. Doing an autorotation downwind would be really, really bad. You constantly have to remind yourself where the wind is in the event of an engine failure.
Sixth, insurance for a helicopter is much, much more than for a fixed wing (unless your fixed wing happens to be on floats) if you insure the hull. The reason is actually pretty simple (like for the float plane). Most helicopter incidents or accidents don't seem to result in fatalities (although the obvious exceptions are wire strikes and failures over water), but almost all helicopter accidents generally involve a hard landing (unless you did the autorotation perfectly and for the private rating they don't even let you do full down autorotations). With a hard landing the main rotor blades flex down and chop of the tail boom. So you just lost the main rotor blades, the tail boom, the tail rotor, the main transmission and the engine. Bummer.
Kinda just rambling here, but I thought I would put some thoughts out there for anyone thinking about helicopters from someone who hasn't really been there but is trying to go there. The little piston helicopters are of pretty limited utility because you just can't put a whole lot of stuff in them and there aren't that many places to put things. But they are way fun and unless you get about 500 hours in a piston, no one will ever insure you to fly a turbine. Weird because the turbine is way more reliable and way easier to fly. I have a little time in a Hughes 500. Now you have a real machine that you can do something with. Substantially more money, but I can still dream.
Oh, yeah, one other thing: wives seem to hate helicopters a lot more than airplanes.
John:
I grew up in Grangeville and still try to get home once or twice a year. Flew in to McCall last July for a family reunion. Do you work at McCall Aviation?
375handh
