Backcountry Pilot • Homebuilt planes.!!!!!!
4 posts • Page 1 of 1
Guys.... if you are going to attempt to build a plane............Please use common sense... This guy didn't and paid the ultimate price....
http://www.youtube.com/watch?v=IJViWG2ZYd4
Stol offline
Re: Homebuilt planes.!!!!!!
Many years ago a Thorp T-18 crashed while turning onto final at Oshkosh, It was caught on video as the wing fold up at the splice. The cause of the accident was when he build the plane he used 1/8 inch aluminum rivets in the wing spar splice where the plans called for 3/16 high-shear rivets.
Dale Moul offline
Dale
Gravity Strikes Again.
Dale Moul wrote:Many years ago a Thorp T-18 crashed while turning onto final at Oshkosh, It was caught on video as the wing fold up at the splice. The cause of the accident was when he build the plane he used 1/8 inch aluminum rivets in the wing spar splice where the plans called for 3/16 high-shear rivets.
I received a call from a friend at Dream Aircraft one spring five or six years ago while I was still building on mine. He told me of the recent crash of a Tundra from fuel mismanagement by a man that I met while in Quebec. The aircraft, equipped with floats, was forced to make a landing in the trees. One tree hit the front of the wing 4' in from the end of the wing. It caved the leading edge in to the spar but did not take the wing off. It did take the eight inch diameter tree down. The pilot was not injured and was able to exit through the door. He rebuilt his aircraft and it is flying today.
My advice is to treat aircraft building like your life depends on it. Building one is more than recreation.
dirtstrip offline
It's not possible to regulate stupidity be it certified or homebuilt....just saying.
Max Torque offline
Location: Arizona/Alaska/various other places around the globe
