Have tried really hard to stay away from this thread if for no other reason the title..."How do I hydroplaning the wheels"
...duh put down dah wheelz in da water and dah hopet ford do best...thats how it comes across to me...no offense...
Have read all the responses...its funny about the flaps, brakes etc. If your not using flaps your only skimming the water for the sake of skiing. Flaps are required for landing. The manuel flaps are key as you can get what you need, now. I generally always come in on approach with 20 degrees and then add as needed when on short final generally ending up with full flaps. The more flaps you have on water, you just add a little more forward pressure. If you cannot wheel land and always 3 point em, dont go and try to ski your plane.
Saw this video the other day...
http://www.youtube.com/watch?v=2NvLqwjNr94You think he could of landed any shorter by NOT using water? NOPE
http://www.youtube.com/watch?v=21El16OPZocListen to the throttle
http://www.youtube.com/watch?v=nj1tmnwiVyI&feature=fvwrelYou do not need brakes at all. Skiing or skiing to land short. Some say, why would you need water to land and that they can land just as short without the water. I personally disagree. Go water skiing behind a boat and then let go of the rope. You slowly start to sink and then end up floating on your life vest with your feet 5 feet below you. You can feel the wheels start to submerge as you coast to shore. As others mention, dont just go out and try it without some idea of making happen. Mauleguy said it best...its the quickest way to ruin your day... You can also add or take away power as needed. To much power/speed you will start to porpoise or maybe I should say, for me, I start to porpoise...no good. When you find the desired speed you settle in and you can go all day around the lake making turns etc.
Using the water to depart is also fine, you just need the speed to make it happen. Current plays a big part. If you decide to use a down river approach or departure you better account for the speed and direction of the current. I had the "Blank" scared out of me trying to land on a gravel bar and did not account for the bend in the river that was running at 6-8knts. The wind also changed and I ended up very lucky and able to abort at the last minute.
My first ever attempt of a water departure actually came only due to poor planing and ended up using the water as I had no choice. It was also with a nose dragger...
Lowrider can elaborate more on that one... I was also very lucky then as I had just enough speed to keep the nose up but it did come down the second I touched water but again had enough speed. I ended up using about 100 feet of water to get out. Dont think I would ever use a nose dragger for H2O work ever again intentionally. Props to those that have and honestly its probably not that big a deal....but! Water / speed = skim....water / no speed = sink...regardless of your machine. Car, plane, tank, body, whatever...heck, Capt Sully even skimmed the big plane on the Husdson for just a little bit.
Capt Sully
http://www.youtube.com/watch?v=ejqYF89dEWwI know many disagree with this whole water skiing thing but really its not that big a deal, I feel personally, but I also get to do it about ever day we fly here. I use it for both landing and departure as many of you have seen. We have a few spots to practice on our circuit, but conditions need to warrant. I could go on and on here. Bottom line, dont even think about it until you can ski (wheel land and keep your tail up) on pavement or grass before you decide to use the water. If your a bouncer on landings your gonna flip your plane on water. You have to commit and feel confident in the ability to not porpoise your wheels. Landing on water is like landing at night without lights. I think everyone would agree, some of your best landings are at night when you cant see your wheels getting ready to touch down.
Good luck. Bring on the neigh sayers...
AKT
