marcusofcotton wrote:onefitty wrote:The NZ CAA in their wisdom have mandated fixed 406 ELT's, the $$/reliability ratio just doesn't work unfortunately so I always carry a 406 GPS PLB. If I'm over water it's strapped to my lifejacket otherwise it's always within reach. I've included switching on both the fixed and the PLB in my engine failure checklist, useless at low altitude I know... This far south there can be several hours delay with satellite passes to figure a position whereas the GPS unit will zap out the coordinates pronto
I think the SPOT and Spidertracks etc would be worth it
I now carry a new Kannad PLB thanks to Flightlogic's generous offer. Is it reasonable to expect one could deploy it in flight during an engine out? Guess I should study it more and pretend practice. Seems it would also be quite vulnerable to damage or loss during the landing with it out and the antenna undone.
Mark J
Mark,
None of these handheld PLBs is going to be able to get a GPS position very quickly, even if they have a good view of the sky. That'll take a few minutes....not long, but probably longer than you'd be gliding.
I'm a big believer in the 406 ELT with GPS enabled. My ACK 406 is connected to my Garmin 396 handheld, which is on any time I'm flying. In the event of an engine failure, for example, I would DEFINITELY activate the ELT manually, with the remote switch. That would send a distress message to MCC within 50 seconds, with my I D and current position. If nothing bad happens in the "arrival", I can always turn the thing off. RCC, after they're alerted by MCC, is going to try to call you via phone if they receive an alert. So, if you happen to have cell phone coverage where you landed, you'll receive a phone call from the nice folks at Tyndall AFB in FL. Tell them no worries, or send out the troops.
My initial ACK unit had a bad switch and it activated in turbulence going into OSH last summer, right after installation. I was descending to Fisk when I hit some low level turbulence and the ELT alerted. Within a couple minutes, my cell phone rang, and it was RCC at Tyndall. I was sorta busy landing at the time, so called them once on the ground. They were very nice, and happy that there was no need to search. Case closed. And, yes, RCC told me that they had a series of GPS locations, as my beacon transmitted every 50 seconds with a new location, until I parked. They were able to tell me very precisely where I was parked as well. And, ACK replaced the beacon at no cost. The new one works fine and no unintentional alerts. Cheapest 406 around with GPS connectivity, and if you already have an ACK 121.5 box, the 406 goes in the same mount.
I carry a PLB in my vest or pocket as well. That's my last ditch gadget if everything else fails. But, like any GPS unit, it'll take a LITTLE bit of time for it to find itself once deployed, and being inside a cockpit decreases the liklihood that it'll work. Remember, not only does the PLB have to receive enough satellites to geo-locate, it also has to then transmit the distress signal out to the satellites. If a satellite isn't in view through your windshield.....
I leave the PLB as a ground device, and an essential one. The newest ones are tiny and not nearly as expensive as the earlier ones.
I also carry a SPOT, but that's a comm tool to let my wife know I'm still around.
