Identifying bad hydraulic lifters
The old school way to test pump up and leak down rates on lifters was to place them in a pie pan full of clean oil and set them on an arbor press or even a drill press. A push rod was chucked in the press and placed in the end of the lifter, you could pump the feed handle which stroked the lifter, and pumped it up with oil. When it was solid you would stop and maintain pressure to see how long it took to bleed down.
If you wanted you could rig up a pressure gauge, they used to list specs for this procedure.
Anybody else old enough to have ever seen or done this?
shorton offline
662
- Aircraft: Stinson 108-2
shorton wrote:Anybody else old enough to have ever seen or done this?
Yup. Me and Crower go way back.
Intercostel offline
31
- Aircraft: 182L Skylane
Sat Feb 09, 2019 10:25 am
Back when we all had our own way to pronounce Iskenderian Cams ? I see in the ads now that they have given up and just call 'em Isky. Crane sure was easier.
Sent from my SM-G950U using Tapatalk
Hman442 offline
101
- Aircraft: Cessna 182H
Sat Feb 09, 2019 10:27 am
Turned off my signature !
Hman442 offline
101
Sat Feb 09, 2019 10:31 am
3386
