Backcountry Pilot • Instrument study materials recommendation
25 postsPage 2 of 21, 2
Re: Instrument study materials recommendation
There is a lot that you'll learn for the test that you'll never use in the real world.
True, but just as true, there is a lot in the real world that you'll never learn for the test.
Examples (all from my own real world, some from my younger and foolisher years):
    When you pick up unexpected ice while on final approach, your windshield goes opaque, and the ice builds on the leading edges so quickly that it's shocking--and it's still there when you land;
    When you forget to turn on your pitot heat in visible moisture, it freezes over, and when you finally remember to turn it on, the circuit breaker pops;
    When you see St. Elmo's fire in your windshield;
    When you're flying in heavy rain and all of your avionics quit doing their thing;
    When you realize that the only legal alternate within fuel range on a flight from Laramie, WY, to Casper, WY, is Pueblo, CO;
    When you're starting to collect unexpected ice in an airplane that is neither FIKI nor famous for being able to carry any ice at all, and ATC tells you that you're number 4 for the approach to Jackson, WY;
    When you're cleared for the approach to Durango, but the previous 3 airplanes have gone missed to their alternates;
    When the manifold pressure drops to zero in IMC, your engine is only windmilling, and the nearest airport is reporting 200' ceiling and a half mile of visibility.
Fortunately, a lot of what you'll learn, whether from reading, or DVDs, or recurrent testing and quizzes, but especially from doing and from others who have been there before you, is to use your skills and judgment to avoid getting into situations which are over your head or beyond the capabilities of your airplane. There will still be times when you'll be faced with situations which you've never heard about, and that's when you'll assemble all that information and ferret out your own answers to the situation you've found yourself in. But hopefully, you'll learn that the best solution is not to have gotten there in the first place, so those situations will be relatively few.
Exactly! That's why you have to get out and be exposed to it. The written test, while important to have an understanding of the basic principles, is by and large a hoop to jump through. Really learning how to operate in the IFR environment requires participation and preferably some guidance from someone with real world experience, not only in flying IFR in the system, but also in a similar aircraft that you'll be flying. Flying IFR in jets with lots of power, ice protection, and almost always in radar contact is different than flying a GA aircraft with limited power, no ice protection, and often operating in a non radar environment.
Just a quick PREP... Last week I started on the King IFR web course. I am really digging it. Very easy to understand and laid out in a concise manor. Would recommend. I started out on the free sportys course to "test" it out, and wasn't happy. Bought the King and was glad I did. Only downside is watching Martha bounce around in time. Obviously lots of the film clips were done 25 or so years ago. One second she is 40, the next 70, and then 50 etc... Other than that, Its great.
www.avthreads.com
"One second she's 40, then 70, then 50"
But at least she is consistent with the dew she sports.
MAU MAU offline
Maule MXT-7-180A
I'm still poking at my instrument rating with a stick. But I have found something that I think is fantastic and I'm actually quite surprised.
XPlane.
http://www.x-plane.com/
To make it as realistic as possible I also purchased:
http://xforcepc.com/store/index.php/gaming-peripherals/eclipse-yoke.html
and
http://xforcepc.com/store/index.php/gaming-peripherals/pro-pedals.html
Originally I didn't get the pedals but I got tired of running off thru fences on takeoff and crashing on landing.
I also purchased:
http://www.x-hangar.com/store/index.php?_a=viewProd&productId=37 and removed some of the gauges and radios, replaced others, and moved them into as close a configuration as possible to match my A185F. I also changed the prop configuration and rpm limits from the 3 blade to a 86" 2 blade.
I find this is making an excellent platform to practice approaches, holds, and all other annoying things IFR.
I can set up the weather scenario I want, or have XPlane use actual weather conditions. This is generally my favorite configuration as it mimics turbulence, winds and weather I would actually encounter.
But the best feature by far is it interfaces with Foreflight (and Wing-X and Xavion and ...) so I can fly just as I would in the 185, taking advantage of the IFR Plates, Airport Diagrams, Terrain Maps, Hazard Advisor, every feature available in Foreflight like you are actually flying in your plane. Very cool.
In addition to IFR training I'm also using it to preflight the route I'll take when bringing the SQ-2 home from Alaska in the spring.
I'm not a video game guy at all. Think they are a massive waste of time. But I can say this set up is definitely worth it.
If it would be of any value I'd be happy to grab some screen shots and post them.
Oh, and I'm doing all this on a Mac (and of course it works on Windows - Gag)
Barnstormer offline
Aircraft: C185
