Prosaria wrote:There is quite a bit of stuff in the list of owner preventive maintenance items that could be interpreted as allowing you to tackle parts of the job.
http://www.aopa.org/Pilot-Resources/PIC-archive/Aircraft-Ownership/Preventive-Maintenance
YMMV...
(1) That might appreciably affect weight, balance, structural strength, performance, powerplant operation, flight characteristics, or other qualities affecting airworthiness; or
(2) That is not done according to accepted practices or cannot be done by elementary operations.”
bat443 wrote:As an IA I would be unhappy to find the control cables which run up aft side of the rear door post exposed with no protection from interference from improperly stowed items or for example a passengers sleeve. Same for the aileron cables that run aft of the rear spar carry through. An unknowing passenger could hang something from a cable on approach when you are looking forward and you may miss it. Remember there are pulleys at the bottom of the door post and you don't want anything falling in there that could jam between a cable and a pulley when you turn the yoke or move the flap handle. For those of you with young children, little fingers, cables, and pulleys don't mix, hate to have a child loose a finger. All wiring needs to be secured so it doesn't hang down and fuel lines should be protected also. All of these are things any mechanic should be checking for on any inspection, with or without an interior. Other than that I think the interior is for decoration, comfort, insulation and sound proofing. So, if I was to inspect an airplane without an interior (will never happen as I only work on my own airplanes and after all these years and thousands of hours of flying I am not a good enough pilot for 50 pounds of interior to make any difference) unless provisions had been made to address these items I would not sign it of as airworthy. Your mechanic may feel differently.
Karmutzen wrote:Citabria interior, looking to improve the sides aft of the door. Currently old, old hide of the nauga held up by a spring on top and stapled to the wooden floor. Chainsaw type cargo tends push out to the outer fabric, especially when you pile it up.
Anybody replace the cheapo vinyl with something a little sturdier and more protective like .025 aluminum or some other fireproof plastic panel?
Did ACA ever upgrade their newer aircraft in this regard?
