Further reading:
http://www.aircraftspruce.com/catalog/avpages/dualxgps170.php
Any suggestions would be greatly (immensely) appreciated
. Thank you.
. Thank you.8GCBC wrote:New iPAD Air 2 (purchased 10-MAY-15) will not connect to my Dual XGPS150. Old iPAD it works fine. IOS 8.3 on both.![]()
Further reading:
Any suggestions would be greatly (immensely) appreciated. Thank you.
rw2 wrote:8GCBC wrote:New iPAD Air 2 (purchased 10-MAY-15) will not connect to my Dual XGPS150. Old iPAD it works fine. IOS 8.3 on both.![]()
Further reading:
There is a known bug in 8.3 connecting to bluetooth GPSes. I'm sure that's what you're hitting though I can't explain why the old iPad is working.
There is not yet a patch for 8.3 to fix this, but Apple has acknowledged the bug.
TomD wrote:Return the iPad and tell the merchant that the iOS if faulty and want one w/ 8.2 or lower.
I am still running 7.1.2 since the iPad does everything I want it to w/ that iOS I don't see any reason at all to upgrade and let the San Jose gear heads screw it up.
TD
soyAnarchisto wrote:Instructions for how to downgrade the device to iOS 8.2:
http://www.redmondpie.com/how-to-downgrade-ios-8.3-on-your-iphone-or-ipad/
fshaw wrote:While some may criticize non-TSO navigation equipment and slam Apple, I can buy a bunch of Apple and BadElf for the cost of a certified Garmin.
rw2 wrote:fshaw wrote:While some may criticize non-TSO navigation equipment and slam Apple, I can buy a bunch of Apple and BadElf for the cost of a certified Garmin.
And also, the entire point of a beta period in something like IOS is to allow developers to test their products and report bugs to Apple. It's amazing to me that none of the Bluetooth GPS vendors were testing the IOS betas. I bet they are now.
fshaw wrote:
BadElf has a purchase program offering two GPS receivers that are 8.3 compatible, the Pro+ and the Lightning plug in for 50% of their suggested retail. I purchased the Pro + ($149 from BadElf) because of Apple's slow/no response to the 8.3 problem and the info about the 8.4 Beta.
NZMaule wrote:Anyone using the external Garmin Glo there is an update from Garmin that appears to work around this. I am on iOS 8.3 and just updated the Garmin Glo and appears to be working now. I needed to restart iPad and re-pair the Glo though.
soyAnarchisto wrote:I think it's fairly safe provided you stay away from any process that invovles "jailbreaking." All this is that someone has saved off the older iOS install image and you do a little trickery on your PC/Mac to fake iTunes into thinking that is the latest image. Not anything damaging or permanent. You can always reset the iPad to factory defaults and restore it again to the latest/greatest (8.3).
To my knowledge there are no bluetooth GPSs that work with 8.3 - everybody is pissed and waiting for a fix. You can use internal GPS if you have it or you can use a wifi based GPS like the Stratus from Appareo. But anything bluetooth-based is hosed.
8GCBC wrote:Spent literally about 20 Hours configuring/loading this new iPAD Air 2. For my feeble mind...It's best to go with an IOS 8.3 compliant GPS and bite the freaking bullet. Who know? I may like the change?
