courierguy wrote:A conversion using the SmartCar diesel" http://www.eco-fly.de/english
Winchester 73 wrote:Are all diesel engines water cooled?
dirtstrip wrote:courierguy wrote:A conversion using the SmartCar diesel" http://www.eco-fly.de/english
I couldn't open the link but did find this about that. http://www.dieselair.com/2008/03/news-f ... craft.html
on the Rotax, so no worries for a while.courierguy wrote:Two of those Smart diesel conversions could make for an interesting twin design, just saying.
They do have the Mercedes thing (rep) going for them, though I'm sure the company washes their hands of the use in aircraft. No doubt, like most all auto engine conversions, it is only as good as the reduction system and other sub components. The fuel economy sure sounds good, more then a gallon per less then the 912S, more or less, though diesel is higher. But, buying off road/nondyed/not road taxed diesel, would help out there.
EZFlap wrote:Diesels have more compression, which means more forces trying to rip the cylinder off the crankcase, which means a lot more metal in the structure to hold it together, which means higher empty weight / less useful load, which means less take off and climb performance, which means larger wing area, which means a heavier airframe structure, which means more power needed, which means a bigger engine... round and round. This concept is affectionately called "the weight spiral" by airplane designers. It's never as simple as it ought to be.
Also, diesel fuel is a lot heavier than gas, although a lot of that is made up by the extra efficiency of the diesel.
All that being said, because of avgas problems and costs, it is indeed time for the diesel engine to emerge and become a viable airplane option... but there have been smart people trying to do this for a while now. The weight of the (inexpensive) automotive diesels is the barrier. As an amateur's guess, methinks that one solution is to make the crankcase or block out of plastic and carbon, or aluminum with the carbon embedded in it. There have been improvements in the carbon reinforced metal world, as well as high temp resins for plastic engines. Heck if you had to, you could machine an engine block out of Micarta with carbon straps around it in the right places. If and when they start to mass produce aluminum diesels for small/light cars, that might be the game changer.
Stol wrote:courierguy wrote:Two of those Smart diesel conversions could make for an interesting twin design, just saying.
Actually the off road diesel is dyed red..... Taxed diesel fuel is natural in color.... I think .![]()
Ben.
Bob wrote:while this is generally true I think the advances in design and manufacturing since GA engines where designed and the new deisels is more then enough to offset the diesel's need to be stronger.
I honestly think there is a good chance that these weights could be trimmed down quite a bit.
I think it's long past time we had a viable diesel option.
Glidergeek wrote:The Future![]()
I don't mean to burst any bubbles or be the bearer of bad news or anything, butttt the state of Kalefornia in conjunction with the EPA here recently has engaged in a battle with any industry that has anything to do with any equipment that is powered by diesel. They have deemed "diesel particulate matter" as a very dangerous substance. Here is an excerpt from one section of there web page. I suppose part of the appeal of having a diesel under the cowl is that you could pay $.10 less per gallon at the airport and run Jet A.
"Diesel engines emit a mixture of air pollutants, which are composed of gaseous and solid material. The visible emissions in diesel exhaust are known as particulate matter and includes carbon particles or "soot." Diesel exhaust also contains a variety of harmful gases and over 40 other cancer-causing substances. In 1998, California identified diesel PM as a toxic air contaminant based on its potential to cause cancer, premature death, and other health problems. In addition, diesel soot causes visibility reduction and is a potent global warmer". This diatribe goes on for pages if you've got the patience to continue to read it.
I've been to several CARB workshops over the past couple years and am assured that this too will be coming to a state near you soon compliments of U.S. EPA. We're just going to ruin the Kalifornia economy first. I don't know for a fact but I would bet to get a diesel engine certified for an airplane without a DPF (diesel particulate filter) here in Kali or the U.S.A. will be a major challenge.
http://www.arb.ca.gov/legis/legis.htm
Zane wrote:I think "diesel" has become a bad word associated with dirty combustion. Few laymen realize that Jet A or "jet fuel!" is just kerosene, a less refined crude product that is for most practical purposes, diesel fuel. Its main characteristic being lower volatility, which prevents autoignition at pressure. Apparently this is desirable for turbine applications. I would like to learn more about that.
Anyway, CARB are the bastards who play the bad guy in the movie "Who Killed the Electric Car?" which can be found on Netflix. No love lost there.
Rob Burson has a newer Dodge diesel pickup. One day he had the ass end pointed into the hangar, running while he unloaded some stuff. Normally, diesel fumes are gagarific, but I smelled NOTHING. It was blown away. Who knows how much the emissions gear to accomplish that weighs, but it was impressive. I am positive that his big ass truck is more economical than my slightly smaller early-model gasoline Tundra (18 mph.)
