Zzz wrote:I'd say only jack them one at a time, and chock tailwheel and the grounded main solidly.
robw56 wrote:I've had a couple close calls when jacking up the 170, especially going from small to big tires. The plane wants to move laterally away from the jackpad and fall out the higher you raise it. What I do now is clamp the pad to the gear leg on each side with a couple c-clamps and that seems to do better. I have some thick rubber I use between the pad, clamps, and gear so I dont damage the gear leg. I usually use a hydralic floor jack that will lift high enough with a block of wood on top that the point of the jack pad kind of digs into and is more stable than being metal to metal.
rocket wrote:Once you get to 31" its time for a set of lifting eyes and a hoist.
Every plane that comes into my shop gets a set of lifting eyes.
Rocket
robw56 wrote:I've had a couple close calls when jacking up the 170, especially going from small to big tires. The plane wants to move laterally away from the jackpad and fall out the higher you raise it....
