I have used the tapered jack-pad units which slide up onto the gear legs, both home-made & mfr'd by Bogert, but they usually scuff the paint. Tried c-clamping a piece of 2x4 onto the gear leg & jacking against that, but it wanted to slip. The best thing I've used so far was something I made years ago. It was designed to be compact to carry along in the tool bag, in case of tire emergencies, but it works better than anything else I've tried.
The jack-pad consists of two pieces of 1x1x1/8" angle, 3-3/4" long, with two 5/16" holes at 2-3/4" center-to-center, along with two 5/16" x 1-1/2" bolts & nuts. The angles are wrapped in duct tape where they contact the gear leg, & the bolts have 1/2" long pieces of 5/16" ID vinyl hose around them to prevent scuffing the edge of the gear legs. I boxed the end of one of the angles, otherwise the corners tend to bend up where the jack bears against it. My little floor jack came up short in the elevation department, so I used a 1/2" drive 1" socket to give me that little bit extra.
