Those are Dinner fish! The big ones stay in the water, to much for one or two meals!
Your 172 exp. if its a 180hp will give you a perfomance index, not quite as fast Stall 39kts, climb 700+ hot summer, 1000-1100 winter light, low alt cruise 105kts, higher alt cruise 110kts ( 8k DA). Its a draggy airplane and is a little alt. challanged, ceiling is supposed to be 14.5k, and I've had mine close but its a struggle. There are a few turbo 200s out there and of course they do better. I operate out of one lake in the cascade mtns @ 2.5k all summer and at near gross during summer ( DAs 3.2? ) thats 1 nm long with trees at the end, when its glassy and no head wind its enough .
The wing AD ( In MHO it was a BS deal by some people to sell parts ) is one time with a flashlight and mirror inspection @ annual, about 10min worth. Airs ( http://www.airinnov.com/ ) is one of the premier Lake shops, Paul was the enginner at Lake that developed the 200EP, 250 & 270T and has some 12k hours in the planes. His inspection check list is very exstensive aand covers it all.
The baggage is behind the rear seat, seat back tilts forward for access for small stuff, or for major packing seat lifts out in 2 min.held in by belts about 10lbs. Baggage box is about 4.5ft long and 34 inchs wide and 16 high, ( main fuel tank is above ). When out camping solo I slide the co-pilot seat forward all the way and actually can and do stretch out and sleep in there with my feet in the bag box ( No rear seat )
It actually is a pretty good rough turf airplane
( I probably just turned the heat on Some of the strips I hit are in MT. Schafer, Meadow Creek, Spotted Bear. In ID Magee, Cavanaugh, Moose Creek. Also while not fast I make it from Watson Lake, the Yukon to Seattle in one day as long as its at least good IFR. ( I don't do hard IFR with it).
As irishc180 indicated ramp queens can be very intense restorations, they are quite complex for there size, and alot of it is hard to get at! Not like your 172! But for as complicated as they are they are quite durable. I've seen one that was bellied into an alfalfa field after an engine failure that required no more the the engine to be fixed and the alfalfa stains cleaned off the hull, absolutely no damage!!
As far as the accident rate, its almost always lack of training and proficency, its really not that difficult to fly well but it is different! The Lake community has a comprehensive syllabus that has significantly impacted the issue that was present back in the 70s-80s. A lot of the planes don't fly alot in the winter and few folks tend to jump in them and head to the wilds, with out working up to it in the spring. Guess what happens, just like alot of the spring accidents in other aircraft.
I've had mine for 11 years and about 1600 hours and can't imagine being with out it! But having a Cub or Scout in addition to get to places the Lake can't go would be GREAT
Hope I havn"t bored you, KAM
