Zane,
It's a beaver pond. Beavers need enough water depth such that they have water UNDER the ice all winter, because they don't ever come above the ice in winter, they stash their food in the bottom of their ponds, and swim out of their houses through a tunnel that goes from their living area in the house to the water below the ice. In the north, that means five or six feet of water, at least. So, that's clue one.
Bear in mind that there ARE dumb beavers, who build a dam and house, only to freeze out the first winter......
Next clue is those lily pads along both sides of the pond/landing area. Those lilies will only grow in water that is between about 18 inches and three feet deep. So, you'll note as he approached that the pond was SURROUNDED by lilies, which implies that between the lilies is deeper than about 3 feet, hence deep enough for that airplane.
Finally, those lilies grow in muddy bottom lakes.....Not to say there won't be a stray rock there, but.....the likelihood in that kind of country is pretty low. So, if he did touch bottom, all he'd do is slide through the muck.
That could well be the country I worked for twenty years in interior Alaska, classic boreal forest, probably near the Arctic Circle. You learn to look at the vegetation, and understand the physics. As borntofly noted, you can land on mud easily.....steering sucks--variable to non existent.
I've landed in lakes (and I use the term loosely) where I couldn't turn around because the "lake" was muck. And, I couldn't wade to shore, because there was almost no bottom. So, power close to shore, grab a line off the tail, slosh to shore, and tug the bugger around so you can unload and then launch. Then, disrobe to pick the leeches off before the next leg.
Lotsa fun. That Otter driver had lots of help turning around and getting going, which can be the toughest task in those places.
