Backcountry Pilot • Larger tires on my 182S —order the kit?
25 postsPage 2 of 21, 2
Re: Larger tires on my 182S —order the kit?
Glad it helped. Bogert Aviation makes some great stuff and they're terrific folks to deal with.
Ross
pipeliner offline
I am hoping to have the 182 back in the air this weekend.
Some great info here on the forum. I'll probably do a write up on all the mods.
Thanks,
D.
ddivinia offline
It is back in the air. Thanks for all the info. I am still getting used to it.
D.
ddivinia offline
Also, we always “installed” a short piece of heavy split hose on the nose strut, held in place with hose clamps. In the event of a flat nose strut, it prevents metal to metal, which is not good. And in some rough stuff, if pressure is kinda low, you can bottom out the strut.
Provides a wee bit of cushion, and can’t hurt.
mtv wrote:Also, we always “installed” a short piece of heavy split hose on the nose strut, held in place with hose clamps. In the event of a flat nose strut, it prevents metal to metal, which is not good. And in some rough stuff, if pressure is kinda low, you can bottom out the strut.
This works good and I run this on a lot of customer A/C as well. But on some of the 182s that have the cut down strut and big fork, there is not enough strut showing to put much of anything on there.
