Leading Edge Tape?
Hey all,
I wanted to pick y'alls brains to see if anyone had a preferred method of protecting the leading edges of your plane? I'm wanting to take some preventative care on the Citabria before it gets any nasty nicks on the tail.
I did a search to make sure I wasn't posting a common question, so I apologize in advance if this has been answered a few times.
I picked up some 3M Vinyl tape for now, but the red is slightly off and I'm not thinking this will be a long term fix. Has anyone had any luck with a clear tape?
Thanks in advance!
ATXCitab offline
78
Tragically, ATXCitab (Hank Sasser) perished in a crash in August 2014. He was a great guy and will be missed. -Z
Sun Nov 24, 2013 11:12 am
Barnstormer offline
2700
- Aircraft: C185
Sun Nov 24, 2013 11:23 am
That has definitely been a thought as well. Plus I could be consistent and put the black on the white landing gear, which would also look good.
Has anyone tried out a clear tape personally? Or at least seen it in person. I'm thinking that might be hit and miss depending on the brand.
ATXCitab offline
78
I haven't personally but a friend of mine had clear tape on his for a couple years. It was relatively thin stuff, but did the job of deflecting most of the paint chipping hits. He said every year he'd pull it off and re-tape it. Long term, he ended up going with the Cessna protector which is rubber, prevents the rocks (most rocks) from denting as well as the sand/grit chips.
TheRebeler offline
37
I have always used the 3M polyurethane tapes in clear. I get it from Aircraft Spruce. It is very durable and can even be painted..
flybymike offline
43
Ditto.
3M has a couple of thicknesses but the thickest does not fold around the leading edge of the horizontal stab well at all. If anyone is interested, let me know and I can dig out my spare roll and try to get the catalog number off it.
I have a couple of "scuffs" in the tape that surely would have been a ding without the tape.
TD
TomD offline
1113
- Aircraft: Maule M5-235C
I have the cessna black rubber leading edge. It is thicker on the leading edge and then tapers as it wraps around the Horizontal. Probably the best. I have tried clear chafing tape and over time it turned yellow. 1-2 yrs.
Hsivany offline
52
- Aircraft: 185
Wed Nov 27, 2013 12:15 pm
3M product I have is 3M 8673 Clear. See below:
http://solutions.3m.com/wps/portal/3M/e ... RCHW15WVblThis is UV resistant and according to info, does not yellow.
This thickness is easy to work with but still provides protection. The thicker tapes probably will need to be custom formed or take a lot more work to get around a leading edge.
TD
TomD offline
1113
Wed Nov 27, 2013 12:19 pm
We tried out the 3M tape in Africa on the Caravans, it all yellowed. Use touch up paint.
dogpilot offline
- Took ball and went home
902
- Aircraft: Cessna 206H Amphib, Caravan 675 Amphib
Thanks for the info everyone!
ATXCitab offline
78
Users browsing this forum: dabridgham and 1 guest
