Barnstormer-
I was thinking about putting my new E-04 exactly where you did.... ended up putting it back in the original spot because there are just too many little holes in this airplane. The old hole pattern was perfect so it won out.
gunny
hotrod180 wrote:Let us know how that starter works out for you. My 180 has a TCM Energizer-- good starter in good shape, but heavy. Not gonna change it unless it starts giving me problems, but it's always nice to have a plan B in mind ahead of time.
NZMaule wrote:Back to strut cuffs Barnstormer, any chance of a photo of the upper strut cuff installed? I take it these are the new STC'd 185 split cuffs you installed?
I'm about to order some but have an antennae plug coming out of one of my inspection panels for telemetry aerials and was wondering how much surface area the strut cuffs use up over those inspection panels compared to the rubbers, in particular the inspection panel just behind the strut.
Well it looks like I'll need to add wingtips to the list. The AeroLEDs and the 185's wingtips don't actually match very well.
aktahoe1 wrote:Ever thought about having some thick rubber around the strut there as it enters the fuselage? I have some 1/2" rubber that goes around mine and replace them yearly. Seems like they take a beating and would be something you want for certain. Almost looks like the metal has been cutting into yours when those gear legs flex?
AKT
Barnstormer wrote:aktahoe1 wrote:Ever thought about having some thick rubber around the strut there as it enters the fuselage? I have some 1/2" rubber that goes around mine and replace them yearly. Seems like they take a beating and would be something you want for certain. Almost looks like the metal has been cutting into yours when those gear legs flex?
AKT
AKT,
I hadn't but it sounds like an excellent idea. Couple of questions, where do you get your rubber, and (it's been awhile since I've had those plates off) do you still put the plates over the rubber or does the rubber's thickness keep it in? If you get a chance to post a photo please do.
Thanks
