AKT
I really have been there and done that with the water landings!! and water skiing.
And in my experience, though it has been awhile, when you get slow and are on step, your tires will start to turn, and when they do start to turn they start to throw water everywhere, in doing that they create a whole bunch of drag real quick and then you sink through the surface.
I found that when the water disappeared under the nose if I let up on the brakes, shoved the tail down and dumped the flaps, you sunk in the water right at the shore and only had to roll a short ways on the beach back on the brakes enough to get the tail in the air to stop! If you are landing on a mud beach (tide gut), you definitely want your brakes locked when you get there! If not in about 10' you cannot see anything.
Take Off, if you are using the wate to continue your take off run and you are close to being heavy, I think you will find you better damn well lock up the breaks about the time you hit the water! If you don't the wheels are spinning at what ever speed you are traveling and they throw just a whole bunch of water.
Take a look at Greg's video that he about lost the Sherpa, I believe if he would have had the brakes locked he would not have dunked it quite so deep. My opinion only and as you know we all have one!
A few of my water skiing's were with a 185 with 29's with tread on them, all the rest were in a M6 with both 29's and 31BW, the one thing I did notice is that with low, low pressure in the BW they were a lot more grabby, I went ahead and put 12 psi in them on the water.
My opinion only, a bit of experience doing it, some at gross wt.
Take it all with a grain of salt, or exlax, which ever works.
GT
Had to edit this a bit!!
I agree that you don't need to use the brakes to water ski at a high rate of speed, but I think if you are using the water to get into and out of an otherwise unusable short strip, then you will find, using the brakes almost necessary when you get to that 3mph difference between sin or swim!!
Again my thoughts only, take it for what you want.
An old fart who still is!
GT
M6RV6 on Sat Jul 14, 2012 11:48 am, edited 1 time in total.
