This thread is meant to address light helicopter mechanics and pilots who are interested in acquiring tools and knowledge for light helicopters. I hope professionals and hobbyists alike will help share info to assist each other.
There certainly are enough differences in primary fix wing maintenance to justify a new thread specifically.
Note: RHC tech support is extremely efficient and knowledgeable and there is no void in my ships care from RHC. I just felt like sharing information and ideas also online. RHC has excellent support and quality.
Discussion Topics:
(A) Differential Compression Check. Fix wing aircraft have the convenience of a propeller to perform differential compression checks. The propeller makes an excellent handle to hold the piston at TDC. The R44 requires a torsion bar, PN MT091-1, bolted to the starter ring gear to position and hold at TDC.
#8
(B) Every 100 hours the tail rotor drive shaft (TRDS) is checked for runout using a standard dial gauge with an extension, KIT MT260-6.
#6
(D) Oil Filters, B123-2, are specially manufactured for RHC by Tempest. The new -2 requires no safety wire.
#16
MT091-1, MT260-6, (3) B123-2 arrived today:
