Kitfox5 wrote:I think your mission fits a Kitfox perfectly. The biggest advantage of an ELSA is that you can take a weekend course and receive a repairman certificate for your specific tail number. You can't do that with a certified airplane. This drastically lowers the annual cost of maintenance, if you are comfortable doing the maintenance. The other advantage of the LSA is the drivers license medical, but in March that will apply to larger aircraft so if that is the reason you are looking at LSA then you should possibly consider larger aircraft in your price range.
Back to the Kitfox, I would recommend looking for a IV or 5,6,7 or supersport. The earlier models I personally would avoid. Stick with 4 stroke engines, Rotax or Lycoming. The kit fox lands short, takes off short and has a good cruise speed. For all around performance I think it is one of the best compromises. If you have questions or need information for a pre-buy feel free to ask.
Bryan
Cary wrote:Any airplane (and I do mean "any") can end up costing a whole lot more than the purchase price. As they say, stuff happens. So regardless of what you buy, be prepared for unexpected expenses.
On Kitfoxes, I've seen some that look like marvelous airplanes--well put together, and I'm told with good performance. I just talked with a Kitfox owner on Saturday who has flown his several times to Alaska and all over the lower 48. His has a 914 Rotax in it, which he says has been incredibly reliable. As I looked his airplane over, I was really impressed (although his 3 blade prop looked awfully fragile!).
Swolf wrote:Thanks for all the info. Think I will be hunting for a 85hp Tcraft that's not had a pile of electronics loaded on it try to keep it as light as posible. Not a deal breaker if I have to add a starter I think
hotrod180 wrote:Swolf wrote:Thanks for all the info. Think I will be hunting for a 85hp Tcraft that's not had a pile of electronics loaded on it try to keep it as light as posible. Not a deal breaker if I have to add a starter I think
If it's got an 85-8 on it, it'll be a big deal-- no provision for a starter or a generator.
If you think you might want a starter (or full electrical system) someday, get one with an 85-12.
Swolf wrote:hotrod180 wrote:Swolf wrote:Thanks for all the info. Think I will be hunting for a 85hp Tcraft that's not had a pile of electronics loaded on it try to keep it as light as posible. Not a deal breaker if I have to add a starter I think
Yes I was looking in to that yesterday. I think other options could be getting a higher time 65 hp for cheap and do the upgrade. The 85-12 are surprisingly affordable.
Did just read something interesting. Once I add a electrical system it makes a transponder mandatory?
Swolf wrote:Did just read something interesting. Once I add a electrical system it makes a transponder mandatory?
contactflying wrote:Just a thought on -8 change to -12. If you ever want to sell your Taylorcraft, Cub, Champ, Luscombe, or whatever, supply and demand might make the plane that never had an electrical system worth more. Stay low and you can go downtown so long as you don't enter the underlying class D. Lots of Midwest "Downtown " towerless airports have or are near good restaurants.
contactflying wrote:No radio required. Totally nonelectric. Grandfather C under B and outside D. We used to call ahead for tower clearance but probably non controlled airports best nowadays. Once -12 stc'd he can't go back. I don't know about 2020 but totally nonelectric has been saved through other airspace changes.
IFR safest but why go partial with a 7AC or similar?
hotrod180 wrote:...... The other advantage of the LSA is the drivers license medical, but in March that will apply to larger aircraft so if that is the reason you are looking at LSA then you should possibly consider larger aircraft in your price range. ......Bryan
contactflying wrote:I thought starter and generator (-12) was considered electric.
CamTom12 wrote:contactflying wrote:I thought starter and generator (-12) was considered electric.
I thought -12 was an engine difference, like the E2D you see at the end of Lycomings, I didn't realize it was the installation of a starter and generator on an 85. Learned something new today!
